Question about HobbyTron Nano Hercules Unbreakable 3.5CH RC Helicopter 3-Pack Bundle Deal
Need instruction for Hercules RC helicopter
Instruction manual
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
How long should charge the battery in my nano hercules helicopter
I re-categorized your post for you. It was posted in the MP3 player section. It should take approximately 20 minutes to charge, but it could take longer depending on the wall adapter and the cable you're using to charge it. Also, if you plug it into a computer it will take longer as it puts out less power.
Dec 26, 2015 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Sanhaun 6050 helicopter manual
dear sir i need sh-6050 heli menual
Dec 25, 2013 | Falcon Radio Rc Helicopter
My back rotor for my Hercules Helicopter's wont work need help!
Motor failure. They don't last long. Look on fleabay for a cheap replacement. If you have a soldering iron, you can unsolder them both and insert a 3v watch battery. If it runs, then it could be the control board or else the transmitter stick control.
Jun 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
I turn the on switch on the remote control and ready to fly. The heli starts for about two seconds and shuts down?
I have a Hercules "unbreakable" helicopter that shows that"shut down" sympton when the battery is low. I assume it does that to prevent the battery completely dying while in flight.
Feb 23, 2013 | RC New 3 Ch Co-Comanche RAH-66 Helicopter
Bought Nano Hercules RC Helicopter. Flew it once and now lower rotor won't turn. Tried to call World Tech
I, too, have the Nano RC heli. Mine spins and spins faster if I try and take off.
Yours is a relatively easy fix. There are SCREWS under the rotor blades on the bottom. Tighten those.
Dec 28, 2012 | Toys
HobbyTron Nano Hercules Unbreakable 3.5CH RC Helicopter 3-Pack Bundle Deal Logo
90 people viewed this question
Top HobbyTron Toys Experts
King
King
MeAndMyBrain
Level 1 Expert
 Russ Hill
Russ Hill
Are you a HobbyTron Toy Expert? Answer questions, earn points and help others
