Question about Vizio Televison & Video
VIZIO E470i-A0 LED TV has weird vertical lines on the panel
My VIZIO E470i-A0 LED TV has these colored changing vertical lines on the left side of the panel. Total width of the lines combined is appr. 5". Sometimes the lines are gone when I turn on the tv but will come up after a few seconds anyway. What part is causing this so I can change if. Thanks
techman
  • 3130 Answers
SOURCE: vertical flickering color lines instead of pictures
Soory man there is no deflection yoke or vertical output IC in a plasma TV set.LOL This person has a problem with whats called the substain power supply or bad caoacitors in the main supply. there is also a possibility that the set has a bad tuner. Only performing test on the set will determine the problem.
Posted on Mar 23, 2007
  • 18 Answers
SOURCE: Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
Posted on May 31, 2008
  • 116 Answers
SOURCE: Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Posted on Dec 11, 2008
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Posted on Feb 18, 2009
  • 23 Answers
SOURCE: plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Posted on May 02, 2009
Vizio E470i-A0 not powering up, the standby led comes on momentary when the pwr button is pressed. The voltage on led1/led2 would spike to 130v when powered then bleed down. Are my led strips are bad?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 14, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Vizio e470i-a0 has a blank screen but has sound.
The led strip is faulty. Normally it's comes with the panel.
If you wish to know bout the Woking of back light LED the check the below added link.
www.electro-medical.blogspot.com
Jul 01, 2016 | Vizio Televison & Video
Vizio E420I-A0 Black Screen
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Vizio E470i A0 Blank Screen No Backlights How to Test Power Supply...
Testing TV Backlight LEDs
Testing tv backlight leds EsBuzz net
http://www.badcaps.net/forum/showthread.php?t=41334
Mar 10, 2016 | Vizio E420I-A0 42" LED TV 1920x1080, 120...
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Vizio TV has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 02, 2015 | Vizio Brand Original Remote for E320i-B0...
To fix no video Vizio E470i-A0 TV
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 21, 2015 | Vizio Televison & Video
Televison & Video Logo
97 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
