Syntax error I have two errors coming up does anyone know what is wrong? offending command k.Z!A5KBNQ"?M, n offending command bin obj seq, type=129, elements=253, size=64936, non-zero unused (shift 3 pound sign)
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Offending command: get
Offending Command: get. Graphics format in pdf document is not handled:
If you are the creator/owner of pdf document then edit pdf document and check Imported graphics.
If not try updating acrobat reader to last version.
If none of the above works, then only solution is to print document from different computer/printer.
regards
Posted on Mar 12, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
SOURCE: Scanner won't work. Message error
mk:@MSITStore:C:\Program%20Files\Hewlett-Packard\Precisionscan%20Pro%203.1\gtf.chm::/vbscripts.txt
Posted on Dec 02, 2010
What does error syntax mean
You enter a command. It is like an English sentence with a syntax (correct structure). If the structure of the command is wrong, you have a syntax error. You could use a minus - sign, instead of a change sign (-) that constitutes a syntax error.
May 27, 2014 | Texas Instruments TI-84 Plus Silver...
SYNTAX ERROR
I am willing to bet that if the calculator could talk she would tell you to stop feeding it commands that make no sense. Joking aside, each command has a certain syntax, similar to sentences you make in English: a prescribed order of the components of the sentence.
For some calculators (the older generations) you press a number then the square root key to get the square root. For the newer ones, you press the square root key. The calculator keeps waiting until you enter the radicand, then it calculates the root.
So before using the command you must know in what order to press the key sequence. If you get an error with a certain key order, do the opposite.
Now, why is the calculator giving you a syntax error always?. There could be may reasons.Try a simple addition or a multiplication. If you get a syntax error, it may be due the computational mode. You may be in statistics mode , or some other modes, I cannot begin to guess, because you say nothing about what you were doing when you get the errors.
Try to reset the calculator to get to default computational mode.
May 22, 2012 | Casio Office Equipment & Supplies
1650en produces syntax error when printing
Have the DRAM and SRAM cleared. Will lose a lot of settings so make sure they are written down.
May 21, 2012 | Konica Minolta MAGICOLR 1650EN COLOR LASER...
Syntax 07 Error
Syntax 07 error may occur from the next reasons:
1. If the command contains a syntax error. Look for misplaced functions, arguments, parentheses, or commas.
2. Exponents can not be more than three digits.
3. Sign = is not valid in parentheses excepr where an expressions is required.
4. Axes in DifEq must be Q, t, or Q'
Mar 12, 2012 | Texas Instruments TI-85 Calculator
How do I clear ERR:SYNTAX on my TI-84 plus?
When you get an error message you can clear it by pressing the CLEAR button. To prevent the calculator from firing off that message, you have to look at the command you entered. The message says SYNTAX ERROR meaning thet the way you typed in the command and its argument is incorrect. Usually you get a quit or GO TO with any message. To see exactly where there is something wromg select the oprion GO TO and the cursor will be at the exact point where there is an error.
Unfortunately one cannot help you here because you do not specify the command, nor what you wer trying to do when the meassage popped up. The message is generic and not specific. There are scores of commands and an unlimited number of ways to write them wrong.
Sep 22, 2011 | Texas Instruments TI-84 Plus Silver...
What is ERR:SYNTAX on ti-84 plus calculator
If you want to correct the error you will have to disclose what you were trying to calculate.
Anyway, each command has to be written in a specific way ( a specific sequence of symbols) to be understood by the calculator.
Foe example, if the command is sin(X) you cannot write it as sin() X or X sin. You must respect the way a command is to be entered, otherwise you get rubbish or a SYNTAX ERROR message.
Usually the calculator will ask you GO TO or QUIT. If you choose GO TO the cursor will jump to the place where the error occurred and you may be able to correct the syntax.
Apr 14, 2011 | Texas Instruments TI-84 Plus Calculator
My calculator fx-991 Es is showing either syntax error or dimension error while finding out the inverse of the matrix although the matrix is a square one
How about recreating the error and reporting faithfully the error message? You get a syntax error if you try to invert a matrix by using the wrong key sequence such a
[SHIFT][MATRIX][3:MatA][X to ] -1), meaning that you use the universal power key on the same row as X squared and log and between them.
To calculate the inverse of a matrix, have the name of the matrix on the command line, (see above) then press [X to -1] key one row up from [log].
Concerning your implied affirmation that if the matrix is square you should not be getting any error: You will get an error ( a Math error) if determinant of the matrix is equal to zero.
Mar 13, 2010 | Casio FX-115ES Scientific Calculator
Can you correct my error message? command line option SYNTAX ERROR I get this message when I try to open a pps file. I have Microsoft Power Point installed on the computer. Thea.
In computer science a syntax error ( IPA: /ˈsɪntæks ɛrə(ɹ)/ ) refers to an error in the syntax of a sequence of characters or tokens that is intended to be written in a particular programming language.
For compiled languages syntax errors occur strictly at compile-time. A program will not compile until all syntax errors are corrected. For interpreted languages however syntax errors cannot be detected until runtime and it is not necessarily simple to differentiate a syntax error from a semantic error.
A syntax error may also occur when an invalid equation is entered into a calculator. This can be caused, for instance, by opening brackets without closing them, or less commonly, entering several decimal points in one number.
copy and paste this link in your internet address bar for more information:
http://www.google.com/search?q=SYNTAX+ERROR&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
feel free to ask any other questions
Oct 13, 2009 | Microsoft Windows Vista Home Premium with...
k24674
