Question about CinchWorks PicBlock
What are problems with picblock
After installing p[ic block cursor flickering and net not connecting
I have this horizontal flickering problem on my philips 191EI.. Anyone know how to fix it? Thanks
This is not horizontal flickering. The picture is out of synchronization. The problem should be with its sync; separator stage circuit. For most modern TVs, this section will be a part of and IC, and is not repairable. Check what number IC is used as system-chorma-video jungle. It is faulty. Replace it. Before replacing, check all the components connected external to it. For details. You're seeing an out of sync: picture on screen. In this case, audio will be almost OK.
Nov 25, 2013 | Televison & Video
Pc game neverwnter nights won't show cursor during game
it's a problem of your OS bit version.. install 64bit version
Dec 04, 2017 | Atari Video Game Consoles & Games
Logitech m 705 mouse pointer flickering
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens.
Type "Cursor blink" in the "Search programs and file" text box.
A list opens.
Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens.
Click the "Speed" tab. A list of options appears.
The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast."
Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale.
Click "Apply."
Click "OK." The cursor stops flickering on the screen.
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
Cursor/hourglass flickers - everything stops - have to turn computer off to work
Sounds like you might have a virus or infection. Try running in Safe Mode and see if it does the same thing.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click REMOVE SELECTEDRESULTS. The objects will already be selected for you. When itfinishes removing the objects click ok and it will sometimes reboot yourmachine.
Apr 20, 2012 | Computers & Internet
I have a 19 INCH LCD SAMSUNG MONITOR THAT FLICKERS/FLASHES CONSTANTLY>? IIT SEEM WORSE IN YAHOO EMAIL , IF I MOVE THE CURSOR IN YAHOOEMAIL OR TECH SITES IT FLICKERS FASTER. iT`S THE SYNC MASTER...
You could have an inverter board problem or a faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp which provides the back-lighting.
For service. parts and DIY info check out LCD Parts - click in this link to their WEB site : -
www.lcdparts.net
Oct 16, 2009 | Computers & Internet
Activating Windows - used HP Pavilion zt 1130
try to start in safe mode do this by when computer first starts after passing post before the loading windows starts hold down the F8 key it will go to a screen that asks how you want to start windows select safe mode and then try to activate
Jul 15, 2009 | HP Pavilion zt1130 Notebook
IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
Ic sony recorder
Easy solution: Throw it away, and buy a Panasonic. Or any other voice recorder besides Sony!!!
Nov 09, 2008 | Sony ICDP620 Digital Voice Recorder
Blue flicker
im thinking the convergance ic has loose solder connection or is about to go.
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | Toshiba 57H81 57" Rear Projection...
Computers & Internet Logo
Top CinchWorks Computers & Internet Experts
David Payne
David Payne
Are you a CinchWorks Computer and Internet Expert? Answer questions, earn points and help others
