Question about Toshiba E-studio 167 B & W Copier. Print/fax/scan
Set process unit - Toshiba E-studio 167 B & W Copier. Print/fax/scan
"Set Process Unit" error
Checked the Developer unit connector is disconnect
Nov 18, 2013 | Toshiba E-Studio167 Copier
Engine jerks, engine light on
Run fault codes to determine the exact sensor that has failed
The engine light is telling you that the CPU has found sensor/s outside set parameters during the checking process. Have the
sensor/s outside set parameters during the checking process. Have the fault codes read before wasting time and money guessing what has failed. Replace with genuine items only as aftermarket units are not always compatible with the settings in the CPU.
ault
Aug 03, 2013 | 2003 Ford Taurus
The printer is reading paper jam pull out process unit remove paper open rear cover and remove paper close rear cover set process unit and close front cover
Have you checked inside the printer, look to the right of the cartridge carriage sometomes small pieces of paper get torn off by the carriage and can get lodged over on the purge or home positon of the printer, it would also help to know what printer model this issue is with,
Jun 29, 2011 | Office Equipment & Supplies
I have a paper jam the printer is calling a "jam
Please follow the below mentioned steps to take out the processing unit,
>> Open the front cover
>> Take out the processing unit
shreysri_13.jpg Note: Place the process unit on a clean, level surface where it will not be exposed to any sort of impact or shock. The drum in the process unit is sensitive to light and should not be exposed to normal office lighting for more than five minutes. Keep a sheet of paper on it to avoid exposure to light.
>> Check if there is any paper stuck in the machine, if there is any take it out dont apply lot of preasure or the sensors might get damaged. If there is no paper inside, it could be the sensors. Put back the processing unit as mentioned in the next point. Also, take out the paper trays, and slide them back in. Also remove if the tray is holding extra papers.
>> To put the processing unit back, align the pins on both sides of the process unit with the guides inside the machine, and slide the process unit into the machine until it stops.
Regards,
Shrey
Jun 03, 2011 | Kyocera FS1128MFP AllInOne Laser Printer
DENON 1709: The sound is OK when STEREO is setting. Using 5.1 STEREO or MUSIC or CINEMA setting all the speakers are working, except Front Right. I check the volume for each speaker and set it up to the...
The Stereo setting does not use any digital processing and likely avoids the decoding board completely. From your description, either the signal is not being decoded properly or the right channel signal path is being interrupted somewhere. Without taking measurements inside the unit, I cannot tell for sure where the problem lies. Careful examination of the processing board is required here. Take the unit to a repair shop for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair.
Dan
May 29, 2011 | Denon AVR-1709 Receiver
My daughter set lock on LG GT540 and has locked herself out,but has also forgot the password.Any ideas
If you have lock set on your device being a smart device the only solution available to you is to get a hartd reset carried out on the unit. A hard reset is a process which restores all of the units system back to factory default. The hard reset process would wipe off all information on the device from text messages to contacts. And once this is done they cant be retrieved. If this is okay by you then simply take the unit to the nearest phone shop and tell them the problem.
Hope this solution has been helpful?
Feb 08, 2011 | LG GT540 Cell Phone
Ricoh 2045 error code SC350
It can be dirty ID sensor it retires the image unit and it cleans it… This happens when mylar of the cleaning unit is damaged…
Dec 04, 2009 | Ricoh Aficio 450 Copier
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
Enter the maintenance item
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Press the enter key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
ADDING TONER is displayed and installation of toner starts.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
Sa-pt750
Is your main set is on while the transmitter card in inserted on main set?
If so, try do "pairing process" to pair up main set and wireless unit.
Pairing process can found in Operating Instruction manual which come along with the main set.
Jul 19, 2008 | Panasonic Home Theater System System
KXTCD 440 es cannot reset the base unit
If your aerial icon is flashig you can't access to base options, all base options are saved in base EEPROM, you need to follow the registration process, but if registration process is not satisfactory, the problem could be that your RF handset unit is broken and you will need technical asistance, a lot of times only resoldering RF unit the problem is solved, if you have more handset in the same base you can cancel all registrations and to start again, but unfortunatly I think that you have a RF problem (maybe the handset fell to floor and now you have a bad or broken soldiering)
May 08, 2008 | Panasonic KXTCD445 Cordless Phone
Toshiba E-studio 167 B & W Copier. Print/fax/scan Logo
24 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
