Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
Colours blurry - Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
Mine is blurry when i try to take video or pictures. it is so blurry you can only see light and colours
Lens problem. The lens may be able to be repaired or need to be replaced. You will need to have it looked at by an experienced technician. www.austintelstarservices.com
Sep 01, 2010 | Panasonic SDR-S26 Flash Media Camcorder
Tv has picture but blurry almost double picture but not quiete also has oval shape purple colour bottom center
for blurry picture,try rotating your antenna or repositioning it,as it is caused by reflections of signals.
for the purple spot,try shifting yur TV to another place in the room or repositioning it.
Aug 23, 2010 | Televison & Video
My printer is printing blurry lines when im trying to print. grr
Are you using Inkjet paper? or normal office rag? The inkjet paper dosent let the ink soak into it and make lines look blurry, it is amade to dry the ink very fast before it can leak around... Get some good quality "inkjet" paper, you should see better results.
Leave feedback good or bad.
Jan 21, 2010 | Brother DCP-385C Stylish Colour Inkjet...
I have a canon A75. The view screen is blurry
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 16, 2010 | Canon PowerShot A75 Digital Camera
Colours are blurry
Registration problem, the color are not on top of each other looking blurrry. Service mode has a Regristration test that is run and can check registration
Jul 29, 2009 | Konica Minolta Office Equipment & Supplies
Ricoh CL7000 text is blurry/fuzzy
probably only when printing in colour? Black only, is ok right?
It needs to have it's line adjustment procedure done. This is a series of complicated trial and error adjustments performed in service mode that the individual colours are adjusted based on printouts generated by the printer. Can only be adjusted by a service tech with experience with this adjustment.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
Dark Blurry Ink Line
When I print darker color images I get what I call Zebra stripes across the picture on a slant about 1/2 inch apart. Changed the toner and the drums are at 45% capacity. Any suggestions. Thank you.
Sep 03, 2008 | Konica Minolta magicolor 7450 Laser...
Blurry picture
Well it very hard to explain what to do, it sound like you have a convergence problem, not clear I would have to see the pricture, is you problem showing bending of the colours, whitch colours, and why just the left bottom, this is what is curving me off, is there a way you can send me picture, to rlandry@vianet.ca and maybe I could answer beter,
Regards
Bob
Feb 09, 2008 | Sony KP-41T65 41" Rear Projection...
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
52 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
