SOURCE: my sansung monitor bring a lock and unlock menu on the screen
Befor replacing the Control ic please check the micro switches those could also be faulty.
SOURCE: 3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
SOURCE: Pop up menu won't go away.
If you can do the factory reset in the pop up menu, try it. You might have to try with another power supply, cord, or computer and check where the problem is.
SOURCE: How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
