Hitachi axm76e power goes on but nothing happens. and after few seconds turns power off. and the "selection" screen doesnt light up, its seems powerless. is there any easy solution to this?
  • Audio Player... Master
  • 15,557 Answers
This is probably the power supply. In most cases there is a bad capacitor in there. You can have a new power supply put in or have someone fix it with component level trouble shooting .
Posted on Nov 18, 2013
TV repair?
You have to check the power supply board of the tv.if you wiah to know more details about how to repair flat panel television then check the following link
http://electro-medical.blogspot.com/
Aug 15, 2016 | Televison & Video
Playstation lights turn on, But nothing apears on screen?..........
Did your previously had it hooked up through hdmi????? Are you getting sound????? Try with the standby light on pushing in the power button and holding it until you hear a beep or two then let go....wait a few 10-15 seconds and see what happens....
Mar 28, 2012 | Video Game Consoles & Games
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
I have just been given a hitachi AX-M76 hifi system the only problem is it is missing the control lead, can anyone suggest where i can get a replacement
Found a "System Cable" for the Hitachi AXM76!
It's at 'Currys Partmaster' for £12.99p plus post!
When you get to the site enter "Hitachi AXM76" and it will show you a picture of it. Would have posted the picture on here, but the Curry's site won't let me!
http://www.partmaster.co.uk/cgi-bin/search.pl?query=Hitachi+AXM76&frmSFinder_headerSubmit=Search
See if the link works first!
May 29, 2010 | Audio Players & Recorders
The screen goes blank (black) after a few seconds. It comes back on after turning power on and off. then goes blank again.
I have one that does the exact same thing. I tested the power board and there's no voltage coming out of the 12V pins. Defective power board for sure, but good luck finding a replacement, and if so, pray it doesnt happen to that one, as it seems to be a common issue with this model. I'm doing more research as to what is failing on the board so i might perform the repair myself.
Mar 15, 2010 | Hannspree HF257HPB LCD TV
Power light green, but turns on for a second says 'Resuming Windows' and then screen goes black and nothing else happens. Power light still green and another light green with a padlock and number 1 in...
It sounds like windows may be stuck. While turning you laptop on hold down the f8 key. You should get a text menu appear after a few seconds. Select start windows normally and this should fix the problem.
Incidently Asus PCs have an issue with windows hibernation. If you know ho you should disable this feature, if your not sure how to do it, leave me a comment and i'll walk you through it.
#Please take a moment to rate my solution.
Thanks.
Simon.
Rytech Computer Services Limited
Nov 23, 2009 | ASUS Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
60ux58b hitachi
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Apr 29, 2008 | Hitachi 60UX58B 60" Rear Projection...
Hitachi 60" picture flashes on and off.
I've had the same issue although I don't unplug everything. I turn it off and then unplug it from the wall for 10 seconds then plug it back in. Seems ok after that. Has happened 4 or 5 times over the 10 years I've owned it.
Dec 20, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
55 people viewed this question
 Grubhead
Grubhead
