China tv kit
Verticql line
Standby for power suply mising&vartical bottum 1"cut aafter 10 minut full screen
Posted on Jan 27, 2016
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Horizontal sweep absent, is the fault. Vertical sweep is OK. Check for any loose solder terminals or loose connection at the connection goes to deflection yoke. Check all the capacitors related to horizontal scan output. google.com/+GopakumarGopalan
Posted on Nov 19, 2013
I m ramchandra patil, i m used china kit which is used ic hay 22 8873csng6pr6. Eht ok, no picture, no sound. 5 volt,8 volt is ok. Pls give me solution tips. Thanking u
Disconnect the horizontal output transistor, and switch ON the set without it. See whether it switches ON. If yes, suspect both LOT and horizontal output transistor. This is a common fault to this kit. More to say, if the tuner get shorted inside, this might happen too.
Jul 17, 2014 | Televison & Video
Tip
The best advice I can tell you at this point is to go to TV repair kits.com and...
Found this on another page here on Fixya. Thought I would post it again since it helped me fix my TV.
Here are some of the most common symptoms and examples of a convergence problem.
This is a very common failure on Projection sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Note: If you set has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
1fddde4.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing or you can call in a pro.
If you want to do the repair yourself check the site www.TvRepairKits.com.
Their kits include a step by step instruction guide, original OEM STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
1fddde4.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant,step by step instructions, etc.
on Feb 26, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Free tv repair advice
Potentially so, however I would get the TV fully checked over by a professional if it has been subject to a surge. If a component further down the line caused the initial surge replacing the blown cap will only result in another bang as soon as you plug it in.
Mar 21, 2014 | Televison & Video
China tv kit yoke connection
recently i have installed a china kit in AIWA set, the picture is in greenish tint, can I ractify the same with the help of remote please suggest the same step wise with the help of remote.
Aug 25, 2012 | Televison & Video
How can i adjust china tv circuit with 21inch sony crt yoke. Please tell me.
dir tery i use 20 inch monetor crt conact with la76810a tv kit horezantel lin
May 31, 2012 | Televison & Video
I have a sony model KP46WT500, its showing double vision on the screen. What is the problem and What part do I need to get it fix?
it Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The best advice I can tell you at this point is to go to TV repair kits.com and order the complete convergence kit for your model of TV set, click on here please: http://www.tvrepairkits.com/xcart/home.php?partner=larry
no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases,
sounds like you have bad convergence ic's
Feb 19, 2010 | Sony Televison & Video
Colors are now separated. there is a blue or yellow shadow next to object in the image. tried "conver. adj." from the menu and it gives 5 crosshairs (middle & 4 corners) that you would think you could...
sounds like you have bad convergence 'Ics there are completeTV repairkits available on-line for this repair. if you do it yourself make sure you get only kits with original STK replacement IC's with your kit. you have to be careful as there are a few sites thast sell the complete convergence repair kits with easy to follow directions, with china or aftermarket IC'S they will work but do not last!!!!!
GOOD LUCK
Larry Dillon
GOOD LUCK!!!
Larry DIllon.
Aug 27, 2009 | Televison & Video
Red and green images surrounding the programming -
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 06, 2009 | Televison & Video
No picture on tv.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point, is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Jul 05, 2009 | Sony Televison & Video
The tv will not turn on. mitsubishi ws-55909
Jul 05, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
