Question about Video Cameras
Xdcam 3-354 - Video Cameras
What is the solution to error 02-F37
No mvement is detected in the ND filter initial operation check of OP (OP0).Problem with laser.
Jun 24, 2014 | Sony PDW-HD1500 XDCAM HD Compact Deck...
ServiceNavi-EX password
Password is : kaguya
Have a good day.
Mar 25, 2013 | Sony Pmw-ex1 Xdcam Hd Camcorder Ex-1
Pdw u1
This indicates the hard drive has errors from bad sectors to file corruption, the hardware should be tested, maybe possible to repair.
May 08, 2012 | Sony PDW-U1 XDCAM Drive Unit PDW-U1 USB...
Hi when i put the XDcam DLA 50 GB disc in my Sony PDW 510 XDCam recorde geve code 03 - 354 error. i dont know about dat. do You can help me ? Thank
03-354
03: optical drive two-axis (FCS, TRK)
-354: No signal from disc required for OP focus servo can be detected. Disc is not rotating
I would try another disc and if you get the same error call Sony's service center.
Sep 21, 2011 | Sony PDW-510 Camcorder
Error 03-454 on pdw1500 deck
What is error03-354 on my Sony XDCAM PDW-F350L?
Thank you. HELP! email: kaltpro@gmail.com
Jan 18, 2011 | Sony PDW-510 Camcorder
When trying to import XDCAM (SD) clips into Final Cut Pro, the xdcam transfer software is first coming up with the error - ERROR SCANNING DEVICE - The mediapro.xml file cannot be found. This is most likely...
The Sony XDCAM EX series camcorder including Sony PMW-EX1, Sony PMW-EX1R, Sony PMW-EX3 and Sony PMW-350. For FCP users who are facing the same issue to import Sony XDCAM EX MP4 to FCP X, there are 2 solutions for you to fix the problems.
The first solution is using third-party Sony XDCAM Transfer software. Prior to importing Sony XDCAM EX MP4 with with XDCAM Transfer, you may use the Sony XDCAM EX Clip Browse to first copy the SxS-based media to local storage. Then you can ingest MPEG-4 wrapped XDCAM-EX media to QuickTime-wrapped media with XDCAM Transfer application on your scratch disk. Then you can simply choose the XDCAM EX Easy Setup that corresponds to your footage and edit as you would with any other native format in Final Cut Pro.
If the first solution is too complicated for you or you encounter some unsolvable problem when adopting the first method. A much simple but reliable alternative solution is recommended to you. You can use a third-party application to transcode Sony XDCAM EX MP4 to FCP X best native compatible editing codec -Apple Prores, which is specially developed by Apple for fast and fluid post-production editing workflow in Final Cut Pro X.
http://www.multipelife.com/transcode-xdcam-ex-to-prores-for-fcp-x.html
Apr 12, 2017 | Sony Televison & Video
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
