Question about Apple iPad Tablets & eReaders
My Ipad 2 suddenly will not turn on - iPad Apple Tablets & eReaders
    New Friend:
  • 167 Answers
Is it fully charged? Try a reset by holding the power key down for several seconds. If not contact the maker.
Posted on Nov 18, 2013
No sound for iPad. Sounds just suddenly stop, what can Ido?
Make sure u are using a oem charger -setting-sounds--then battery
Oct 02, 2017 | Tablets & eReaders
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Jan 01, 2017 | Apple Tablets & eReaders
How do I fix IPad 2 freeze up?
Make a new back-up of your ipad, do a factory reset and then restore from the back-up.
The two most common reasons for resetting an iPad to the factory default settings are to prepare the iPad up for a new owner or to overcome a problem with the iPad that simply rebooting the iPad won't solve.
settings -> general -> reset
Jan 08, 2015 | Apple iPad 2 Wifi 16GB
My simplyVibe suddenly stopped connecting. It makes the appropriate beeps but I get a message it is not connecting. What can I do?
Sheila,
If the steps you listed above do not work - try:
1. Taking out the battery of your SimplyVibe.
2. Count to 30.
3. Put the battery back in. If this doesn't resolve the issue, please let me know and we can explore other avenues.
I've also included a link to their product support page. I hope this helps. Take care and have a great day!
-Alex K.
Support Portable Speakers
Nov 29, 2014 | Tablets & eReaders
I have an iPad 2 that suddenly started to freeze up. When it unfrozen on its own after a few minutes, it suddenly went crazy, hopping from app to app very quickly and typed things on some apps and la
I guess, by reading your question, that the iPad 2 have the latest IOS (9.3.5). Most of this problem are related to the IOS firmware, it is simply terrible for a device with just 512mb. of memory. Next time it freezes, just press home and power button until you see the Apple logo, once the logo is display, let go of the buttons.
Jun 26, 2017 | Apple iPad2 WiFi 64GB
What can my problem be
such symptoms usually occur only when the battery is weak and need to be replaced.
- other reasons can be:
1) a faulty charger
2) a bad cable
-change to another electric outlet
-let the iPad be connected with the charging cable while using
-to have a better control about battery status activate battery percentage display to ON in the settings
How to see the battery percentage in my iPhone's status bar.:
- The iPhone ships with this feature disabled by default, and Apple hides the option away within the device's general settings. So, here's how to enable it!
Open up the Settings app on your iPhone and tap on the 'General' tab. You'll see an option "usage"
then you'll see an option for 'Battery Percentage' - simply turn this on and your iPhone will now display your remaining percentage next to the battery indicator in the status bar.
problem-z4ipswfycprf0ccft4hwg0fn-3-0.jpg How To Display The Battery Percentage On Your iPhone iOS Tips Cult of Mac
problem-z4ipswfycprf0ccft4hwg0fn-3-2.jpg Enable Battery Percentage Meter On iPhone iPad or iPod Touch
Aug 31, 2014 | Apple iPad 32 GB WiFi Tablet PC
My ipad will no longer auto rotate. What do I do?
There is a switch over the volume buttons on the edge of the iPad. It can be used to lock the rotate function. Check that this switch is off
Aug 13, 2014 | Apple iPad Tablets & eReaders
My brand new Apple IPAD Air generation 5 won't turn on
Return the unit. it should still be under warrinty
Jan 29, 2014 | Apple iPad Air
All of a sudden the icons are too big and don't fit into the screen. I'm unable to use the ipad or even to see/open all apps.
I believe that you may have the accessibility mode turned on. I think if you double tap with three fingers it should return to normal.
Jan 09, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
47 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
