Ricoh Aficio SP C730 error code SC277-01.
Prompt please transcript service codes for this printer.
  • 37 Answers
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Posted on Nov 16, 2007
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
  • 29 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Posted on Aug 18, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
How do I get my w2's
Transcript or Copy of Form W 2 ' Internal Revenue Service
https://www.irs.gov/faqs/irs-procedures/copies.../transcript-or-copy-of-form-w-2
  1. Cached
Refer to Transcript Types and Ways to Order Them for more information. You can also use Form 4506-T, Request for Transcript of Tax Return. Check the box for Form W-2, specify which tax year(s) you need, and mail or fax the completed form. Allow 5 to 10 days from the IRS received date to receive the transcript.
Missing Your W2 Here is What to Do ' Internal Revenue Service
https://www.irs.gov/newsroom/missing-your-w2-here-is-what-to-do
  1. Cached
If you have not received your W-2, follow these three steps: Contact your employer first. Ask your employer - or former employer - to send your W-2 if it has not already been sent. Contact the IRS. After February 14, you may call the IRS at 800-829-1040 if you have not yet received your W-2. File your return on time.
What can I do if I have not received my W2 from a previous emplo ...
https://ttlc.intuit.com/.../2238273-what-can-i-do-if-i-have-not-received-my-w2-from-a...
  1. Cached
  2. Similar
Feb 15, 2014 - Request or download Form 4506-T. You will receive W-2 transcripts which will have information reported by your employer to the IRS free of charge. Call (800)829-1040 to obtain the form. 3. Request Form 4852 from the IRS or download it and mail it in. How can I get a copy of my W-2? - TurboTax Support 16 Nov 2017 How can I get all my w2 forms from all my employers from more ... 8 Mar 2017 How do I get a new copy of my 2015 W2 from my company. They ... 14 Apr 2016 I haven't filed prior year taxes because I misplaced W2's. Compa ... 17 Jan 2016 More results from ttlc.intuit.com
Feb 15, 2018 | Heating & Cooling
I have a problem with my toshiba e-studio35. he give me a code Call for service 435218 can you help me please
  • Phone Number
    800-457-7777
  • Talk to a Human
    Press 0 at each prompt, ignoring messages.
  • Call Time
    Average Wait: 14 mins - Mon-Fri: 8 am - 8 pm CST
Dec 08, 2014 | Toshiba e-Studio 35 Copier
What is CEEB code
CEEB codes are identification numbers for specific locations and organisations. They were created to prevent confusion and ensure things like test scores, transcripts, and applications go to the right places.
CEEB stands for College Entrance Examination Board
May 07, 2014 | Clothing
Problem with Olympus AS-2400 PC Transcription Kit
I saw the AS2400 is compatible with Windows XP/2000/Vista.
You can install Windows XP in your computer (I presume you have a 4th Gen Intel processor installed in it) and run this software under Windows XP.
On the Windows 8.1 Help and Support, search: Windows XP
Mar 07, 2014 | Olympus AS-2400 PC Transcription Kit
My printer spoler is not working
Hi g k,
Have you tried restarting the print spooler from services?
Start the Print Spooler service from the Services console
  1. Click Start, click Run, type services.msc, and then click OK.
  2. Right-click the Print Spooler service, and then click Stop.
  3. Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following commands at the command prompt: net stop spooler
    net start spooler
    exit
    Note Press ENTER after each command line.
Hope this helps, and please rate:)
Gary
Aug 01, 2013 | Samsung Office Equipment & Supplies
Voice text
Voice recognition software will not give the accurate transcription.Better Go for Manual transcription Services
Oct 16, 2012 | HTC Incredible S
How can i retrieve an email chat with a specific technician?
If you are signed in to FixYa, go to My Profile and see if the chat is not listed there for you to access.
Aug 25, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
FixYa
post your problem and I'll re-answer it now.
Nov 02, 2008 | Office Equipment & Supplies
174 people viewed this question
k24674
jasbo
jasbo
