Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Samsung wa13g7q1 top loader
This Samsung top loader washing machine is not draining water automatically. All other functions are working fine. After I physically drain out the water then it starts spinning/drying cycle.
    Champion:
  • 242 Answers
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Posted on Nov 18, 2013
  • 136 Answers
SOURCE: samsung wa13g7q1 gives se error
Please check the following :
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Posted on Jan 20, 2010
SOURCE: I have a samsung front
sgh samsang s5230 ringer problem
Posted on Jun 02, 2011
  • 6277 Answers
SOURCE: I have a Samsung Top
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Aug 12, 2011
SOURCE: Looking for a Samsung WA13G7Q1 washing machine user manual
u can get that manual from below given link
http://www.manualsmania.com/download.php?link=9bf2da2386f59b40b986333f91ad7463356fd759
Posted on Dec 14, 2011
tanda400
  • 7 Answers
SOURCE: WASHING MACHINE NOT RETAINING WATER
Make sure that
A. the drain hose is above the hight of the water level.
B. there is an "air gap" between the drain hose and the stand pipe as the water can "syphon"out.
Posted on May 04, 2012
I have a Samsung WA13G7Q1 top loader giving me a DE on LCD when spin cycle starts then just stops.
DE is an error relating to the lid switch/lock not working, if it cant sense the lids shut it wont spin, it could be as simple as the magnet in the lid has moved or the more likely cause is the lid switch has died, it will require further inspection or you could just order the lid switch and see how it goes
Jan 28, 2017 | Samsung Washing Machines
My Samsung 13Kg Top Loader WA13G7Q1 continuously drains out the water when the drum is being filled , what could be the problem
Either your in house drain pipe is too low or your drain pipe is down into the drain too far and this causes a siphon effect. Pull drain line up out a little at a time until it stops draining while filling. Good Luck!
Jul 28, 2015 | Samsung Washing Machines
Samsung washing machine 13kg.top loader model wa13g7q1, machine intake water run for a while then changed operation into drain and drained water for a while then display IE error . what will be the...
The problem is the pressure sensor is either clogged or defective or a broken wire. To check if you know how to take apart look for sensor with small clear hose attached. Put some water into tub and disconnect little hose and blow into it you should hear like blowing into milk glass with straw. If no then you have a clog if yes you have bad sensor or wiring. If not able to find this call 1800 Samsung for there products.
Mar 17, 2014 | Samsung Washing Machines
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
I have a Samsung Top Loader fully automatic washing Machine WA13G7Q1 and only a little water runs in then it stops. What could be the problem?
John C
Aug 12, 2011 | Samsung Washing Machines
I have a Samsung WA13G7Q1 washing machice The
the quection is not complete, when the cold water inlet and hot water inlet both work then what is the problem....
Apr 27, 2010 | Samsung Washing Machines
Error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
De error code on samsung topo loader stops working
0E - OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
Feb 28, 2010 | Samsung SW62ASP Top Load Washer
Samsung wa13g7q1 gives se error
Jan 20, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Water drains in wash cycle
It is probably a solenoid valve for the drain that is stuck open. There could be an object in it or may be defective.
Jun 12, 2008 | Washing Machines
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
220 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
