Question about Samsung SCX-4100 All-In-One Laser Printer
We can not print because there is an text "open heat error" on the display. What is this problem?
  • Samsung Master
  • 15,633 Answers
The fuser is burned out. Replace it.
Posted on Nov 18, 2013
2 Suggested Answers
  • 360 Answers
SOURCE: open heat error?
check your heater roller i think it is thermistor broken
Posted on Jan 22, 2010
Error messg 016-700 Memory Full
Try this, it may be a large print job held in memory.
Press 80-0-1327 to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
Oct 01, 2014 | Dell 2135cn All-In-One Laser Printer
Pcl xl error error: insufficient memory operator: rectanglepth position : 751 How do i correct this problem
Solution
The possible reasons for this error message are as follows:
  • The document is containing both image and text.
  • The font is not supported.
  • Embedded fonts are used.
  • A special plug-in is used.
This issue can be fixed by enabling the following option in Printer Preferences .
To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet CM2320 MFP Series PCL 6 , and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Rameshkumar . R
cberamesh@gmail.com
Aug 24, 2011 | HP LaserJet P2015 Printer
Estudio 161 4h error code
h4 low heat from heater unit do the following [c key]-[auto/text/photo key]-[c key]-[auto/text/photo key] machine will go dead key in 14 press print machine will cycle if the error code returns you will have to replace thermistors and thermofuse
Mar 19, 2011 | Toshiba E-Studio 161 Copier
Showing error 0xc19a0020 Ink systme has failed. Unable to copy, recieve faxes, or print
The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .
Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
    1. Remove the cartridges from the product.
    2. Wait for the 'Insert Cartridges ' message to display on the control panel.
    3. Disconnect the power cord from the back of the product.
    4. Wait 60 seconds.
    5. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
    6. Reinsert the cartridges, and then close any open doors on the product.
    7. If you receive a prompt to print a calibration page, do so.
    8. Reconnect the USB cable to the rear of the product, and then try printing again.
Mar 06, 2011 | HP Photosmart C6180 All-In-One InkJet...
You must have a record. hp p1006 printer envelopes hang in print que. I have spent many hours with your staff and the problem hasn't been solved?
Envelpopes should be printed using the feed tray located in the front of the printer not through the paper cassette. Try this: Follow these steps to print on envelopes from a computer running Windows. NOTE: For specific details on formatting text for printing on envelopes, consult the help files in the word processing software. For best results, consider using a label for the return address.
  1. Click File , and then click Print . The Print dialog box opens.
  2. Depending on the software program, click Properties , Options , Printer Setup , or Preferences . The printer Properties dialog box opens.
  3. Click the Paper/Quality tab.
  4. Select Envelope as the paper type.
  5. From the Size drop-down list, select the applicable size. To create a custom size envelope, use the following steps:
    1. On the Paper/Quality tab, click Custom .
    2. Click in the Name text box, and then enter a name for the custom envelope size.
    3. Click in the Width text box, and then enter the width. NOTE: Make certain the size is in inches. Click the Use Millimeters/Use Inches button to toggle between using millimeters and inches to define the custom paper size.
    4. Click in the Height text box, and then enter the height.
    5. Click Save .
  6. Click Apply to save the settings.
  7. Click OK to print the envelopes. NOTE: An error message might display asking to load an envelope into the manual feed tray. This might occur even if the envelopes are loaded. Make sure the envelopes are loaded, and then click Continue . The product will continue printing from whichever input tray contains the envelopes.
Dec 17, 2010 | HP LASERJET P1006 Printer
My brother MFC 8860DN printer has an error showing: Rplace fuser. Does it have a fuser and where can I get it?
Open it up from the back of the machine. Try reseating the fuser first. If that does not help, then you need to replace it. Probably the ceramic fuser element is going bad? It is either not heating up fast enough or heating up too fast. If you can print test sheets, and the text is too shiny, it would be a fuser that is too hot. If you can rub the text off the test sheet, it is not fusing fast enough and there is not enough heat.
Try ebay for a fuser. They are fairly simple to replace.
Oct 13, 2010 | Brother MFC-8860DN Printer
Open heat error?
just switch off the printer for 30 minutes and switch it on again.
Dec 01, 2009 | Samsung SCX-4100 All-In-One Laser Printer
My Phaser 7700 Printer does not come to a ?Ready? state
This might be a bad main Image Processor (650-4307-00) board. We can isolate it by printing an internal test print.
You can power up the unit in diags (hold "back" & "info" buttons while powering up) Go to "Built in Test Prints" and try to print the "Grid 1 Dot Pattern"
If you print, then it's proven...
If not, then you will get an error that will allow further troubleshooting.
-Whit
May 10, 2009 | Xerox Phaser 7750DN Laser Printer
Diaplay shows open heat error after one print.
The fuser is overheating. Probably now has blown the overheat thermostat. You have to replace the fuser to get rid of it. Not real hard to do.
Mar 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Error message; no printing of text
What application were you trying to print from at the time. Does the printer give this error message all the time or only from this program? I need this info to assist you bzoe...lilacgerry
Aug 30, 2007 | Xerox WorkCentre M940 InkJet Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
