Avision AV220C2 00-0000496-07G Logo
A
Anonymous Posted on Nov 18, 2013
Error code avision scanner
7
1 Related Answer
TechSatya
Scan Aid
  • 104 Answers
  • Posted on Jul 14, 2008
SOURCE: Avision AV830c plus scnaner paper jam error
Hi, Can you provide the detailed description of the issue? Is there any on screen error message or panel error code? regards, TechSatya
Avision AD8150NP Document Scanner. We installed the driver and software and it gives us error 219 even though we tried to delete everything and reinstall.
Question edited for a lot more clarity and toss in some CAPS.
Link to the manual and maker support. You only get Support on the website if you enter the serial number.
AD8150 - Avision EN
avision.com https://www.avision.com > blog > document-tag
Why Avision · Corporate Profile · News · CSR · Scanner · Document Scanner ... Follow Us. Facebook-f Youtube. Copyright © 2023 Avision EN ' Powered by Avision ...
Avision AD8150NP Document Scanner User Guide
device.report https://device.report > Avision > AD8150NP
Avision AD8150NP Document Scanner User Guide · What's in the box · Install the scanner · Connect to Power · Install the Scanner Driver first and then the Button ...
2answers
Error code (E8)
Error E08 In Avision AV 121, what's wrong with that?
1helpful
Avision AV8350??? the error led is on, first time the led on & off For 8 number Sequence. then on for ever.
When you first turn the scanner back on, the READY light will blink, indicating that the diagnostics are in progress. If the Ready LED and Paper Jam LED blink 8 times, the error indication is "Light Check Fail (ADF)" or "Flatbed /ADF inverter check error".
Followings are the solution for the above problem:
1. Lamp is on? Yes. CCD error, Optical assembly is to be replaced.
2. Lamp is on? No. Flatbed or ADF Inverter error. Lamp inverter circuit is to be replaced.
3. Lamp is on? Yes. Issue resolved.
4. If the Lamp is still off, then Lamp is to be replaced.
5. If the issue still persists, then you may have to contact the authorized Avision Service personnel for further diagnosis and suggested repair or replacement.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
1helpful
Once i powered the avision 220 on, The moniter shows E and 7
When you first turn the scanner on, the READY light will blink, indicating that the diagnostics are in progress. Observe
the front panel Error LED (Red) closely. In a short time, the Error LED indicates the results of the offline diagnostics as
explained below.
Ready LED(Green) is off and Error LED(Red) indicates 7, the error indication is"Face down light check failure".
1. CCFL is on? Yes. CCD error, Optical assembly is to be replaced.
2. CCFL is on? No. Inverter error. Lamp inverter circuit is to be replaced.
3. CCFL is on? Yes. Issue resolved.
4. If the CCFL is still off, then CCFL is to be replaced.
Regards,
TechSatya
5helpful
Top Avision Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Avision Office Equipment and Supply Expert? Answer questions, earn points and help others
