Question about Yamaha Audio Players & Recorders
No OSD menu on Panasonic ST50 plasma TV
I have yamaha RXV 473 connected with HDMI 1.4 cable to panasonic plasma ST50 on HDMI 2 (ARC).Also reciever is connected with optical cable from TV. Problem is that i don't have OSD on screen.HDMI control is enabled both on tv and reciever and everything works ok except i dont have OSD on TV when i enter setup on yamaha.TV automaticly switch to HDMI 2 when i push setup button, but there is nothing except black screen. Do i miss something or i need to eneable some hiden options?
    Top Expert:
  • Yamaha Master
  • 35,672 Answers
My guess is that the OSD function can only be enabled directly at the Panasonic TV.
Posted on Nov 18, 2013
Testimonial: "Hmm,but how ? I searched through all menus and options and i didnt find anything related to "allow OSD from external device""
3 Suggested Answers
jimedington
  • 39 Answers
SOURCE: RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Posted on Jan 16, 2012
dduncan774
  • 760 Answers
SOURCE: OSD on Onkyo TX-NR3008 not working
Your OSD is created in the HDMI board. Since you already have had it replaced, the only thing I can think of is to replace your 2 plugs and your socket. This is the big cable that runs from your operation board to your main micro board. The original socket Onkyo used has bad insulation that over time can cause a varity of problems. For example some switches might stop working, the unit can freeze up, etc. These signals run through your main micro, which in turn tells your OSD chip when to activate. You can easily check to see if your socket is bad by unplugging it. If it is bad you will see residue on or in the connector, and it will have a bad smell to it. Good luck.
Posted on Jun 21, 2012
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
No HDMI video using RX-V575 Yamaha Receiver with Panasonic TV C-P60ST30
Michael, I still think it is a connection problem. Try disconnecting the HDMI and see if you get the video. If no, it is a connection problem. Check the connections carefully.
Mar 24, 2014 | Yamaha RX-V575
I just bought a Sony sound bar ht-st7 I have a Panasonic tc-p50vt25 tv and and a Panasonic blueray player these products don't have ARC. I have been using the red white cable connected to my cable box the...
Your TV does support Audio Return Channel (ARC). Try connecting your Bluray player to HDMI 2 and your sound bar to HDMI 1(ARC). You will need to make sure that VIERA link is turned on in the Setup menu of the TV.
Aug 27, 2013 | Sony Audio Players & Recorders
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Panasonic SCBTT350 Theater System
Can i connect my panasonic viera th-42px8ou plasma tv,to my vista desk top? my tv has hdmi on it,my vista tower also says it has 1 hdmi connector on the back of it
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
Dec 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
Yamaha RX-V530 no OSD
There is no OSD on this unit. The Monitor Outputs are there in case you run video inputs to the receiver, which you don't.
Apr 26, 2009 | Yamaha RX-V663 Receiver
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic CT-32SF36 isn't getting video from A/V receiver
Hello, I hope this message can help you, After reviewing the Panasonic TV info, and the Yamaha reciever info., I have found on page 19 of your owners manual for the Yamaha reciecver that you can connect the the cable box HDMI cable to the reciever, but the reciever needs to connect to the T.V. HDMI.
I see your T.V. has S-video in and your reciever has S-video out, what about your cable box if it has S-video than I would connect all your device together through the S-video jacks.
A further note is you can't down grade the signal from the cable box through the reciever to the T.V., so even though the technology is there on your cable box, it's not there on the T.V.. On that note there is 2 options 1) buy a new T.V. with HDMI inputs. 2) connect the system together using S-video or component cables (RCA). It will give you almost the same quailty if you use good cables. I hope this will help you and I look forward to helping you in the future.
Jan 14, 2009 | Panasonic CT-32SF36 32" TV
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
212 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
