Question about ASUS A7Sv-7S009C/Intel Core 2 Duo T7500, 2GB DDRII RAM, 250GB HDD, DVDRW, 17 TFT WebC... PC Notebook
Sound but no video on startup - ASUS A7Sv-7S009C/Intel Core 2 Duo T7500, 2GB DDRII RAM, 250GB HDD, DVDRW, 17 TFT WebC... PC Notebook
    Novelist:
  • 288 Answers
It seems that your OS has registry problem.
- Start PC in safe mode, normally Pressing F8 key when windows starts up.( Google it)
- In Safe Mode create a new user, with administrator privileges and protect it with password.
- Remove unwanted software's & programs.
- Empty the Recycle Bin.
- Download reliable program RegInOut to fix OS registry properly.
- Restart your PC normally and log on to the new account created.
Stay Happy :-)
Posted on Nov 19, 2013
Video issue macbookpro 2006
startup and regular sound White screen appears but no apple logo appear ,
1) smc have been reset multiple times. possible motherboard video hardware issue cause over heating.
2) hold option key switch on laptop it will be see hard disk or DVD drive (apple disk inside) icon, the motherboard good if icon appeared. and the motherboard video dead if not appear. hope to help a little
Jan 02, 2014 | Apple MacBook Pro with 17" Display
15.4-inch macbook pro A1286 turn on but wont start
  1. Verify startup process passes initial memory checks and POST (Power On Self-Test) with no beeping sounds or flashing sleep LED. Check video activity.
  2. Disconnect any peripherals and Ethernet cable.
  3. Reset SMC using the procedure for your computer.
  4. Reset PRAM by holding down Command-Option-P-R keys while restarting, until you hear the startup sound for the second time.
  5. Start up from known-good original system media or an up-to-date, bootable Mac OS X volume.
  6. Run Disk Utility or check Mac Resource Inspector (MRI) results to verify SMART status of the your hard drive.
Jul 31, 2012 | Apple Computers & Internet
My screen is black with no picture
If you turn on the computer and the lights come on and the fans start but you see no picture, try turning up your volume to listen for the windows startup sound. If you hear the windows startup sound it is likely your video card or the monitor on the laptop. If you hear no sound the power could be faulty or the computer could be completely fried. Follow this link to get your laptop taken care of by HP http://h71036.www7.hp.com/hho/cache/405979-0-0-225-121.html
Mar 15, 2011 | HP Compaq nc6120 Notebook
Monitor troubling by changing the menu settings by itself
If the monitor only displays 640x480 & 16 colors, it sounds like the display adapter is using standard windows svga drivers. (Unless you have a VERY old monitor that can't display more than that.) Have you tried reinstalling the drivers that came with your video card ?
Click on "start", then "Run".
type in "msconfig" (no quotation marks)
It should open the system configuration-thingy.
If it is set to anything other than "normal startup" (ie diagnostic startup), change it back to "normal startup". Click "apply", "ok", and then restart your computer. You will hopefully be able to change your settings again.
If everything fails change your video card
Thanks.If this solution works for you then please rate me.
Jul 07, 2010 | HP Computers & Internet
My pc boots but no video is displayed so my only guess it the onboard video on the motherboard is faulty. can i buy another video card and remedy the problem?
You can indeed install another video card, but this may not be your trouble. Are you absolutely sure your computer is running normally except for the video? That is, do you hear all the other sounds that usually go along with normal startup (hard drive activity, Windows startup sounds through the speakers, etc.)? It's very unusual for a motherboard to fail so that everything works except for video out to the monitor. You might be facing a computer with some other issues, like memory or a deeper motherboard problem, causing it not to start.
If you do decide to install a new video card, be sure you get one that's compatible with the motherboard (proper type connector) and power supply (not a super whiz-bang card that may need more power than your current supply can provide).
Mar 27, 2010 | Computers & Internet
Only Sound
Could be the monitor settings don't match the video output or the video card has failed. Try entering the BIOS setup screen at startup. Usually the 'DEL' key held down. If screen is displayed (It will be in default VGA mode at that point), then you know the video stream is OK. Continue booting, and press F8 to enter windows safe mode, and continue from there to get the display parameters corrected.
Jul 24, 2009 | Lexicon Omega Desktop Recording Studio...
One beep at startup - System does not bootup
You have what sounds like a RAM problem. Try known good RAM as a test. If it still fails, remove add on cards except video. Make sure that video card works. If it still fails to boot. Replace motherboard.
Jun 01, 2009 | E-Machines eMachines Desktop PC
Black screen startup
hello..this is the 1st you need to try..if you have a CRT monitor or LCD Screen try to put the signal Video on the Laptop located at the Back of unit then try to boot your unit...Thanks...
May 10, 2009 | ASUS G1 Notebook
Startup NDS lite tune
it still might be the speaker, most games are on the low sound spectrum, but the start up tone is a very high pitch, speaker might have a tiny hole in it.
Jul 14, 2008 | Nintendo DS Lite Console
ASUS A7Sv-7S009C/Intel Core 2 Duo T7500, 2GB DDRII RAM, 250GB HDD, DVDRW, 17 TFT  WebC... PC Notebook Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
