Question about Seagate Computers & Internet
Drive locked - Seagate Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Seagate Master
  • 2,226 Answers
Its dead get new one
Posted on May 19, 2014
How to unlock my local drive if it was locked by "easy drive lock software"??
To unlock the hard drive unlock x:
The x represents the letter of the hard drive that you want to unlock. For example, if you needed to unlock the C: drive, type c in the place of x.
To lock the hard drive lock x:
The x represents the letter of the hard drive that you want to lock. For example, if you needed to lock the C: drive, type c in the place of x.
Jan 25, 2014 | Computers & Internet
1992 Land cruiser will not shift into drive
Does it have manual locking front hubs? Some people fit these to full time four wheel drive vehicles to reduce driveline effort and increase fuel efficiency. The issue is that the drive from the transfer case will find the path of least resistance which if the front hubs are not locked power will be sent through the front diff and only spin the front drive shafts. To ensure drive power is sent to the rear diff the centre diff needs to be locked. If you do have manual locking front hubs try putting them in the locked position and leave the centre diff button off and try going for a drive.
Mar 04, 2013 | 1992 Toyota Land Cruiser
BAD DISK BECAUSE PASSWORD LOUCK
Issue How to lock / unlock the hard disk drive.
Cause
A hard disk drive may be come locked or unlocked allowing or not allowing for software to have direct disk access. You may encounter an error indicating to unlock the hard disk drive in any of the below circumstances.
  1. Attempting to install another operating system.
  2. Attempting to fdisk the hard drive.
  3. Installing software.
Solutions
To unlock the hard disk drive
unlock x:
The x represents the letter of the hard disk drive that you wish to unlock. For example, if you needed to unlock the C: drive, type c in the place of x.
Additional information about the lock and unlock command can be found on our Lock / Unlock page.
To lock the hard disk drive
lock x:
The x represents the letter of the hard disk drive that you wish to lock. For example, if you needed to lock the C: drive, type c in the place of x.
Jun 16, 2011 | HP Computers & Internet
Sir My system D drive and E drive folders are locked with usb lock ap, unfortunately I format C:drive and installed windows xp. So D drive and E drive usb lock ap folders are not opened. present i...
You need to ask for experts on this - if the drive is copy protected or locked.
Then bring the drive to expert servicemen to open it up to recover you files
Mar 07, 2011 | Advanced Systems USB Lock RP
Weird display light above the power button
those are status indicator lights with the following info:
Indicator Icon Description Modular drive modular.gif The computer is accessing the modular drive. Hard drive hdd.gif The computer is accessing a hard drive. Caps Lock statusd.jpg Caps Lock is turned on. Pad Lock statuse.jpg Pad Lock is turned on. Scroll Lock statusf.jpg Scroll Lock is turned on.
Apr 16, 2010 | Gateway 450SX4 Notebook
How do you replace the ignition switch on a 1994 Lincoln Town Car?
Here is how to remove ignition lock:
   Rotate ignition lock cylinder to RUN position. Using a 1/8-inch drift, depress lock cylinder retaining pin through access hole and remove lock cylinder.
Carefully NOTE: the position of the bearing retainer prior to removal.
   Remove blue plastic bearing retainer by inserting a screwdriver or similar tool, with a 90 degree bend on the tip, between bearing retainer and bearing and by prying upward.
   Insert tip of a screwdriver into Double-D slot of bearing, then rotate 90 degrees. Remove bearing.
   Remove lock drive gear. Carefully note relationship of lock drive gear to position of rack teeth.
Here is the installation:
   Position lock drive gear in base of lock cylinder housing in the same position as that noted during removal procedure. The position of lock drive gear is correct if last tooth on drive gear is meshed with last tooth on rack.
   Position bearing retainer in lock cylinder housing. Insert tip of a screwdriver into Double-D slot of bearing, then rotate 90 degrees.
   Press blue plastic bearing retainer into lock cylinder housing. Ensure retainer is in its original position.
   Line up flats of drive gear with flats of washer by pulling down on the column lock actuator.
   Install lock cylinder assembly.
   Check for proper start in PARK and NEUTRAL. Also, check to ensure start circuit cannot be actuated in DRIVE or REVERSE positions and the column is locked in LOCK position.
May 04, 2009 | 1994 Lincoln Town Car
Optical Drive Device Locked Acer e lock activated. I cannot use my Cd drive.
Acer eLock Management
Acer eLock Management is a security utility that allows you to lock your removable data, optical and floppy
drives to ensure that data cannot be stolen while your notebook is unattended.
Removable data devices - includes USB disk drives, USB pen drives, USB flash drives, USB MP3 drives,
USB memory card readers, IEEE 1394 disk drives and any other removable disk drives that can be
mounted as a file system when plugged into the system.
Optical drive devices - includes any kind of CD-ROM or DVD-ROM drives.
�� Floppy disk drives - 3.5-inch disks only.
�� Interfaces - includes serial ports, parallel port, infrared (IR), and Bluetooth.
To activate Acer eLock Management, a password must be set first. Once set, you can apply locks to any of the
devices. Lock(s) will immediately be set without any reboot necessary, and will remain locked after rebooting,
until unlocked.
You can try this:
You can reset the system to its default settings (all devices unlocked) by removing the password (leave the password fields blank when changing the password).
You also may be able to simply uninstall the e-lock software in add remove programs.
Is there an icon in your system tray that may allow you to disable e-lock?
Dec 30, 2008 | Computers & Internet
HITACHI HARD DRIVE LOCKED
Hello Oldnovii
This Toshiba notebook has both a BIOS and hard drive lock on it. The client has already paid $ 25 to the Toshiba depot to have the BIOS lock removed now they want $ 100 to remove the hard drive lock. The hard drive lock cannot be removed by trying to bypass it using a boot cd or disabling the hard drive boot option in the BIOS. Any help will be appreciated since my client has now had the notebook for 2 weeks and cannot use it. Thanks
Apr 07, 2008 | Computers & Internet
How to lock an Iomega MiniMax 250 GB Hard Drive?
They make chains with locks that screw to a secure surface. (floor,wall, desk, specially made etc.) You then hook you hard drive to the secure lock and someone can't easily pilfer it. Hope that helps, Tim
Feb 13, 2007 | Iomega MiniMax (33464) 250 GB Hard Drive
Computers & Internet Logo
32 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
