Question about iLO MP3 Player
Searching song files
Ive had my ilo for almost 2 years and have had great luck w/ it. Just recently it started showing "searching song files" when I turn it on and that's all it does. Occasionally I can get it to play one song and then it goes back to searching song files. It still works to transfer files and play on other computers, just not on the player itself. this is a big bummer and I can't figure out what went wrong.
  • 1113 Answers
SOURCE: won't play
Sounds like the download is corrupt, delete data and download a single known good mp3 file and retest
Posted on Nov 07, 2007
  • 91 Answers
SOURCE: copying songs from cds
It could be because there in WMA format and the ones you download from limewire are MP3.
Try getting the songs of the cd's again and using this converter to convert them and put them on your mp3 player and see if they work then.
Download Converter Here
Good luck. Hope my solution was helpful in some way.
Posted on Nov 30, 2007
SOURCE: My ilo MP3 player needs help
Posted on Jan 25, 2008
  • 8596 Answers
SOURCE: not showing file list, just searching
Reset, try again
Posted on Jul 05, 2008
  • 8596 Answers
SOURCE: Only Plays 20% of songs
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Finding songs on my ilo mp3
installed Itunes software.. to transfer songs file.
Sep 11, 2008 | iLO (2 GB) MP3 Player
Won't play
Nov 07, 2007 | iLO (2 GB) MP3 Player
It doesn't work the same
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
May 17, 2008 | iLO (2 GB) MP3 Player
No files found
Switch it to MTP or auto mode in settings menu
Mar 27, 2008 | iLO (2 GB) MP3 Player
My Mp3 Ilo wont start
The hold/lock is engaged - turn it off
Nov 10, 2007 | iLO (2 GB) MP3 Player
Use playlist feature in Windows Media Player in MTP mode
Sep 30, 2007 | iLO (2 GB) MP3 Player
Mp3 player won't play
your ILO has somehow lost its file structure. look for a tiny pinhole to reset the device. if none, then remove batteries to attempt reset. if still no songs, then firmware upgrade if possible or copy file structure (using windows) from a friend's ILO.
Jun 08, 2007 | iLO (2 GB) MP3 Player
Song Names show up incorrectly on ILO Mp3 player. Wrong format?
The funny~.mp3 names are usually because the title field is not filled in in the mp3 property tags, so it uses the DOS version of the filename for the title. Under windows, right click the song and select properties->summary->advanced, and make sure that the title field under "description" has what you want in it. I don't think even the makers of Ilo know how it organizes the files.
Apr 17, 2007 | iLO (2 GB) MP3 Player
Incorrect Format Please Reformat the Player
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
  3. Download the correct Firmware
    1. Click here to download the ILO 116 Firmware
  4. Click Open to initiate the download
  5. Double click on the ILO or Siren folder icon. There will be 14 icons.
  6. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
  7. Then click Run - this will open the Install Wizard.
  8. The Install Wizard has the instructions on the screen as you go through it.
  9. Once the firmware has installed, please click the Start menu, then Programs.
  10. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Nov 28, 2006 | iLO (2 GB) MP3 Player
32 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
