Question about Cuisinart DCC-2000
Cuisinart DCC-2000 Coffeemaker
Set coffeemaker to brew then on and it doesn't do anything. Light is on but water doesn't spray out over coffee. Has done this a couple of times before but did brew after a while, today will not brew.
  • 3 more comments
  • Anonymous Nov 04, 2007
    I have the same problem. The light comes on and there is water and coffee but the water does not spray.
  • Nigel Henry Jan 10, 2008
    After successful dryrun and initial cleaning of machine, DCC-2000 set to automatically start brewing. DCC will not start brewing process.
    DCC-2000 then set for manual brewing and nothing happened. Checked all parts to ensure everything was seated correctly, checked water level, took basket in and out to make sure seated correctly.
    Brew light and On light come on; however, no action from coffeeemaker.
  • Anonymous Mar 24, 2008
    Same problem turn it on and nothing. Light on but no coffee, however it has started on its own a few days later! I will be contacting Cuisinart
  • Admwrlk Apr 21, 2008
    Same thing.  Once in past, pressing down the lever to dispense coffee started everything going, but not this time.  Turned to Brew, turned to on, light came on, there is a little click, then nothing.  The heating element inside does get hot, but the water does not go from the reservoir to the "coffeepot" portion.  I'm cleaning the whole thing out, and seeing that the little levers move, but so far, no go.
  • Anonymous May 07, 2008
    I am having the same prtoblem
    I put the coffee maker away for a few days, brought it out again added less than a full brew of the water and got a pot out...then nothing again.
    Called the number listed for warranty support (BIG THANKS!) and was told most likely heating element failure and that, based on serial# or purch date proof, under warranty they would replace for $10 and, since I don't live in CA, I would bear cost of shipping.
    Thanks again for the telephone number
I had this problem and saw a post to contact Cuisinart at 1-800-726-0190. Before calling I was pretty mad that my expensive coffee maker pooped out. Called warranty dept on a Sunday morning and got right through to a very nice rep who was patient while I looked for the serial number - What do you know! It was still under the 3 year warranty and they replaced the pot for FREE (not including shipping).
The ease of this resolution has convinced me to buy a Cuisinart product again!
Posted on Apr 27, 2008
    Problem Solver:
  • 14 Answers
I would contact Cuisinart Warranty at 1-800-726-0190 regarding this issue.
Coffeediva22
Posted on Jan 14, 2008
I was having the same issue - machine not turning on, etc. so I called the # listed on the posts above - and Cuisinart did not put me on hold - I got right through to a person! They asked me for the serial # on the bottom of the machine and offered to replace it! So now we will have a brand new version of our old machine soon!
Posted on Aug 18, 2009
We have the same issue and found that it has something to do with moisture getting in the unit. Have not found a permanent fix, but using a hair dryer to dry it out seems to work.
Posted on Apr 05, 2009
Thanks!  That's good to know.  I found my manual, and decided we hadn't cleaned it recently.  I filled the reservoir with 1/3 white table vinegar and 2/3 water.  That didn't seem to do anything, So I took a syringe and an IV catheter, (it helps to be in health care) and squirted some of this down "sprinkler".  We let it sit a couple of days and every now and then, turned on the coffee maker, and in a couple of days it went.  We put it through again withthe same solution (to clean calcium deposits) and then with water a few times to get rid of the vinegar smell.  It's been working well for two days now.
Posted on Apr 29, 2008
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
Dcc-1200 coffeemaker self clean light blinks
There is no self clean button on mine, and I have done the above with vinegar and water......what next?
Nov 11, 2011 | Cuisinart DCC-1200 Coffee Maker
I lost my manual on how to use the self cleaning on my cuisinart coffee machine
Decalcification
Decalcification refers to the removal of calcium
deposits which form over time on the metal
parts of the coffeemaker.
For best performance from your Brew Central
Thermal™ Coffeemaker, decalcify the base unit
from time to time. The frequency depends upon
the hardness of your tap water and how often
you use the coffeemaker. The flashing Clean
light will indicate when you should clean your
coffeemaker.
If the Clean light begins to flash when the
coffeemaker is turned on, it is telling you that
the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir to
capacity with a mixture of ¹⁄³ white vinegar and
²⁄³ water. Press the Clean button. When the self
clean light glows, turn the coffeemaker on by
pressing the on/off button. The Clean light will
shine steadily. The coffeemaker is now in Clean
mode. One cycle should be sufficient to
adequately clean the coffeemaker. When the
cycle is completed and the five beeps sound,
the coffeemaker will shut off. Turn the
coffeemaker ON to see if the Clean light
continues to flash. If it does, turn it to OFF and
then repeat the cleaning procedure with a fresh
solution of vinegar and water.
If the Clean light no longer flashes, turn the
coffeemaker to OFF and then run one cycle of
fresh cold water through the unit before using
the unit again to brew coffee.
Notes on the Clean F unction
Pressing the Clean button cancels all other
settings. If it is pressed accidentally, press it
again to return the coffeemaker to all its
previous settings. Pressing ON/OFF will also exit
the Clean Mode and turn the coffeemaker OFF.
Directly from the DCC-2400STR manual
Feb 14, 2010 | Cuisinart Coffee Makers & Espresso...
My cuisinart DCC-2000 will not urn on I have only had it for 2yrs what can I do to fix this? Had the DCC-2000 for a little over 2 years. Now it won't do anything. No lights. Nothing. Tried the reset...
Try this and let me know if it works - plug the coffeemaker in, turn the function knob to BREW, and then press all 3 buttons in the center of the coffeemaker (the 1-4 button, et, etc) and hold them for a few seconds. Let me know if the clock display comes back on.
May 28, 2009 | Cuisinart DCC-2000
Clean light will not off after cleaning cycle performed 4 times
Unplug the machine for 20 minutes or longer - don't skimp on the amount of time, or it won't work. After 20 minutes, plug the coffeemaker back in, and you will see that the self-clean light is now off.
Mar 29, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Set up for 12 cups. Starts ok but stops after
Unplug the coffeemaker for 20 minutes OR LONGER (not a second less). While it is unplugged, fill the water reservoir with 1/2 caraffe distilled white vinegar and 1/2 caraffe water. At the end of the twenty minutes, replug the coffeemaker and brew the vinegar/water just like it was coffee. You may have to run it through up to 3 times. If the vinegar/water cleaning fails to restore the coffeemaker to normal, you have a deeper issue. This product has a 3-year warranty, so call Cuisinart if you are within your 3 years.
-Tha Mp3 Doctor
Mar 22, 2009 | Cuisinart DCC-1000 Coffee Maker
After brewing coffee does not stay hot.
Unplug the coffeemaker for one full hour.
When you replug it, go to Auto-Off - change the time from "2:00" to "4:00", and then brew another pot. Immediately after the brewing is done, set the coffeemaker back to Auto-Off and see if your problem is resolved.
If not, it may have deeper problems. These coffeemakers have a 3-year warranty - call Cuisinart to see if you are still in-warranty.
-Tha Mp3 Doctor
Jan 31, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffeemaker getting hot but not brewing
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor
Aug 06, 2008 | Cuisinart DCC-2000
Power off
Aug 02, 2008 | Cuisinart DCC-2000
Turn on coffeemaker and it will not brew.
-Tha Mp3 Doctor
Jul 16, 2008 | Cuisinart DCC-2000
Coffee Makers & Espresso Machines Logo
547 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Norman Worley
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
