Question about Kyocera CS5050 Black and White Copier
Error code h4 01 reset c160 - Kyocera CS5050 Black and White Copier
  • Tech Bravo
    Tech Bravo Nov 30, 2013
    Hi shaj , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    h4-01 is a sharp error. a cs-5050 is a copystar (which technically is kyocera) so what exactly do you have? please provide correct make and model.
Error code L4-05 for Sharp AR-C160 Digital
main motor lock detection
shifter motor trouble
Nov 26, 2009 | Sharp AR-C160 Color Copier
Canon ir3170ci - error e000008-00001
This is a fuser roller life error. The machine has an internal counter that counts parts' usage. This code can only be reset by a technician.
Mar 25, 2009 | Sharp AR-C160 Color Copier
F2-57 Sharp AR C160 color copier
This is a problem with the drum and you may need to replace it to fix this problem...
Feb 16, 2009 | Sharp AR-C160 Color Copier
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Sharp AR C160 - Error H4-00
The thermistor inside of the fuser needs to be reset before you can clear the code. If you remove the top cover of the fuser the thermistor is located on top of the upper fusser roller. It should be reset able by pushing in. Then you put in the reset code. you may want a tech to look into what caused this.
Hope that helps...
Lbcoaster
Sep 16, 2008 | Sharp AR-C160 Color Copier
Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Jul 26, 2008 | Sharp AR-C160 Color Copier
Error code F2-45
Ihave Sharp AR-C160. WHAT DOES THIS H4-01 ERRO CODE MEAN? How do I clear it?
Jul 18, 2008 | Sharp AR-C160 Color Copier
Canon 5870 error code
What is and how do you clear error code H6-00
Dec 27, 2007 | Sharp AR-C160 Color Copier
Ar-c160
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
Dec 16, 2007 | Sharp AR-C160 Color Copier
Kyocera CS5050 Black and White Copier Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
