Elektrolux washer ewf 168540w when pushing the start button it sayes ERR i the display
the dr
  • 447 Answers
SOURCE: help me!!!!!!!!!!!!!
Ok the washer is telling you we have a problem. I will tell you how to retrieve the code and then ill tell you what that code means
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel
buttons simultaneously. As long as the buttons are
held, the failure code will appear in the display as an
E followed by two numbers, a number and a letter or
two letters. The controlwill beep and the Door Lock,
Wash, Rinse,
and Final Spin indicator lights will
flash.
Posted on Nov 16, 2007
  • 1294 Answers
SOURCE: Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Posted on Dec 03, 2007
SOURCE: Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
Posted on Aug 19, 2008
SOURCE: Affinity washer displays ERR. PAU and 56
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Posted on Jan 10, 2009
dblred
  • 68 Answers
SOURCE: loc code
the control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
Posted on Oct 23, 2009
I have an elektrolux washmachine EWF 10470 W. And I keep receiving error EH0. After few days machine starts working and stops again in few days. I called the service but they didnt know.
This isn't so much an answer as a direction to look. Here is a link to an electrolux manual with error codes when I searched for you model of washer. The error code you are saying doesn't show in the list. But may be this will help....
http://manuals.electroluxusa.com/prodinfo_pdf/Webster/137316000.pdf
Dec 25, 2010 | Electrolux EWFLS65ISS Stainless Steel...
Washer won't start
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 03, 2010 | Kenmore HE2 Plus Front Load Washer
Have a kenmore front load washer and shows pau 45 in the display. Whatever button i press shows err cannot do anything with the machine.
Jul 10, 2010 | Kenmore 46462 Front Load Washer
My front load Kenmore washer 44082 does not start. just buzzes and displays ERR.
Nov 04, 2009 | Kenmore 44042 Front Load Washer
My frididare washer will not start. When I push the start button it says err. and loc.
did you try unplugging it for 15 to 20mins to clear the memory then plugging it in
Jun 04, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer (laundry)
try pressing options and select for ten seconds if that doesnt work you have a promblem with the door lock switch open then shut your door firmly try it again if that doesent do it try unplugging the unit for 5-8 seconds then retry if that doesnt do it then pull the bottom panel and look on the left side of the washer there will be a envelope with a tech sheet there with instructions on testing the door lock itself
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Nov 20, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
