Question about JBL EON 518S Subwoofer Speaker
Blew fuse on a 518 s subwoofer but i need to now if there is one inside
Was connecting subs to speaker connections when it popped, turned off and will not turn back on...VSX-518-k
You probably blew a fuse. It should be marked on the back next to where it tells you to turn the power off before connecting speakers.
Good Luck,
Gil
Jul 19, 2011 | Pioneer VSX-518-K Receiver
I have an LG LHY-518 home theater system. It was given to me and I need to replace the subwoofer connector cable. Anyone know where I can buy one?
I am looking for an LG LHY-518 subwoofer connector cable also... have you found where to find one yet? You can E-mail me at smt0471@yahoo.com thank you
Mar 21, 2011 | LG LHY-518 System
I have a LG LHY 518 system and the subwoofer doesnt work. Can I replace it with any LG subwoofer?, or do I need a certain kind of LG subwoofer.
I'd lurk on eBay or other auction sites and see if one becomes available.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/LG-LHY-518-Home-Theater-Systems-manual/id/366ag212/t/2/
LHS-95PAA
Take a clue from that non-standard system cable between the electronics and the sub. It powers the sub's amplifiers and carries signals. Wanna take a chance on the pin-assignments being consistent across all product lines?
Mar 13, 2011 | LG LHY-518 System
My SW 22HT Kenwood subwoofer stopped working.The fuse was bad it was replaced and the new fuse blew again
The reason the fuse blew again is that an overload has occured. It could be a faulty part in either the power supply section, or the amp section. Follow the curcuit from the fuse, be on the look out for damaged, burnt parts, suspect anything on a heat sink.
Nov 30, 2009 | Audio Players & Recorders
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
My basslink worked great, son blew fuse, replaced, now sounds lik
If the speaker has been overdriven, it may have damaged the cone surround or damaged the speaker coil, causing it to 'rub' inside the magnet. To check for rubbing, you need to move the speaker cone backwards and forwards by hand and listen where the speaker coil/cone goes into the magnet. It should be silent if ok. If you can heara rubbing or grating noise, then the speaker is damaged. If the output driver on the amp is damaged it can give a distorted sound, which could easily happen if it tries to provide too much current.
Nov 04, 2009 | Infinity BassLink II Car Subwoofer
Klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Apr 26, 2009 | KLH BB-II Subwoofer
I have an LG 518 System after 1 year i cannot get the sound
have you either replaced system connection cord or any fuses
Jan 30, 2009 | LG LHY-518 System
Subwoofer eating fuses.
Check the circiut board for any blown capacitors. Sometimes it's that simple as replacing a capacitor. But then again, what is causing the capacitor to blow??/ Hope this helps.
Nov 02, 2007 | Audio Players & Recorders
Open Questions:
See all JBL EON 518S Subwoofer Speaker Questions
JBL EON 518S Subwoofer Speaker Logo
95 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
