Question about Canon PIXMA MX320 Color USB InkJet Printer
I can't print with my canon mx320 because a window saying " an error occured while printing" is showing up! what can i do, pls?
The screen used to show "black ink volume unknown" and "a black and white cylinder, plain paper A4" and more...
danasaur
  • 77 Answers
SOURCE: Prints without any errors but no ink on the paper.
if you have new print head assembly and cartridges, and waited for flow, and the printer is MECHANICALLY sound (not dropped or G-force damaged), then all that is left is improper cartridge installation. You may not have the cartridges fully inserted/, or maybe they are not PROPERLY inserted. Look for a snap when in place (and no wiggle). I suspect this is your problem, because one symptom you mention, ink accumulation INSIDE the head/cartridge cradle, is VERY rare -unless the cartridge is inserted improperly. The cartridges/head assemblies have VERY good seals to prevent leakage. Unless the o-rings/seals are damaged, leakage outside the seal just does not happen at all, normally.
*New head/cartridge installs can take several hours -sometimes even a day in cold weather, for small iP90-like printers to saturate the heads -and print.
Posted on Dec 12, 2007
websnail
  • 419 Answers
SOURCE: MP600 printer won't use the 8 BK black ink
Quick and easy way to do this is to use the automatic duplex more as this uses the 8K cartridge instead of the 5K.
Thing to note is that the 8K is the photo black and dyebase whilst the PG5 is a pigment ink.
As a general rule you'll want to use the PG5 because it's cleaner and sharper for text while the 8K is much better for photo quality inks...
... and the reason it's used for duplexing? Simple... it dries quicker! .. So, you don't have to wait as long for the page to be pulled back in and you get less chance of smudging...
Hope that helps...
Posted on Mar 13, 2009
  • 62 Answers
SOURCE: Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Posted on Feb 13, 2010
Danieldesmon
  • 56 Answers
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
Posted on Mar 01, 2010
  • 236 Answers
SOURCE: MP160 PIXMA - will not let me use black ink only -
u should be able to just take it and print if not there is some other problem
Posted on May 10, 2010
Alarm light is on
Have you tried to change change the cartridges. If yes, try to print a page from the computer, follow the on screen instructions.
Feb 27, 2014 | Canon PIXMA MX320 Color USB InkJet Printer
Shows an error - Printer error 5200
I didn't find MX320 in my area but I think MX300 is similar to the MX320. The following is the reset ink counter for a MX300:
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Hope it will help.
Sep 19, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My cannon MX320 printer light are flashing both the on and alarm button - message contact service center, printer error has occurred at the botton of the sceen it shows B200
This error refers to a voltage problem within the print head. Usually the fix is a new print AND the main logic board.
Personally i feel its an end of life error and you should consider replacing the machine as the cost of repair is more than it would be to buy a new printer.
Sorry
Aug 25, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My print is Canon MX320. I just changed a new ink, but the error 5200 occured. Do you know what happened? Thanks.
Error 5200 indicates that the print head temperature has exceeded the specified value. Turn off the printer and then turn on, if error still persist replace ink cartridge or print head.
Jan 30, 2011 | Canon Office Equipment & Supplies
Error no 5200 occurred in canon mx 328
the printer cannot detect the cartridge. remove the cartridge and clean the surface with clothe moistened with alcohol. then return it back
restart the printer and do print jobs
If error appears press and hold stop reset button and wait for the printer to self restart before releasing the button.
Jan 24, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Canon Mx320 printing error 5200.How do I fix it?
Just remove the ink cartridge from the printer and clean the surface contact using a cotton moistened dipped in an alcohol .
Return back the cartridge and try to print again.
Try also to Press and Hold the STOP/RESET button until printer restart. Release the button when to completely initialize the printer
Aug 20, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MX320 Color USB InkJet Printer Logo
old marine
old marine
