Question about Morphy Richards Coffee Makers & Espresso Machines
Coffee dripping through
Machine very slow to drip coffee
    Problem Solver:
  • 7 Answers
If this is a machine that heats the water then it could be a built up of limescale. I would suggest cleaning the machine by running a whole bottle of brown vinegar through it and then just plain water to clean afterwards.
Vinegar is not chemical of course and so its not toxic if you ingest some but i used this process to clean my italian style machine and it made the thing work alot better.
Posted on Jan 03, 2014
4 Suggested Answers
  • 5 Answers
SOURCE: Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Posted on May 23, 2008
  • 19 Answers
SOURCE: slow water drip
First of all it depends on the hardness of the water. Vinegar doesn't really work in the heavy lime belt area of the midwest. It is better if you use lime away. It is an ecolab product that is great at lime removal. Use one cup per pot. Then rinse two pots worth if this is the kind of machine that uses the same water that is put in during each brew cycle. Some brewers have a reservoir. Bunnomatic is an example of that kind of brewer. If you use lime away in that kind of brewer you need to run about thirty pots to remove all the lime scale remover from the brewer. Slow brewing can also be caused by over softened water. I drove from Indy to Iowa after installing a brewer and then a day later the store put in a softener and over softened the water causing the coffee filter to clog up with sodium. Also check the sprayer disc or head where the water comes out. Over time coffee "paste" will build up around the outlet and if you don't wipe it clean or "smear" the coffee grounds around the outlet that will slow down the brewing cycle. I have thirty years as a brewer technician and it is usually one of the things I have covered, providing that the heat element isn't defective.
Posted on Aug 20, 2008
  • 13 Answers
SOURCE: The "Brew Pause" feature doesn't work
It's the spring part on the bottom of that black basket. Now that it's broken there's really no fixing it. The only thing to do is call the manufacturer (800-726-0190) to get a new brew basket. They are open on weekends, so you could call them today and see what they can do (brew baskets are covered under the 3 year warranty, btw). Just have your model and serial number and you can probably have a new one ordered in less than 5 minutes. :)
Posted on Aug 29, 2009
Testimonial: "Very helpful suggestion to call the manufacturer. I was told to try the self-cleaning, as calcium deposits could be the problem. worked like a charm."
Slow drip process
Sounds like your on the right path, this is what I would look at next.
Nov 25, 2011 | Coffee Makers & Espresso Machines
Coffee drips so slow. coffee stops dripping
Have you tried descaling. Run white vinager through it. instructions for this procedure are in the manual
May 26, 2011 | Keurig B50 Coffee Maker
My Bunn has a slow drip. Model GRX-B. Have cleaned the disc sprayer and pushed the spring up in the hole. What else can I do? It used to drip a lot faster.
How old is the machine? If you have cleaned it and delimed the machine and it still is dripping slow, the machine may need to be replaced. Please call service at 800-352-2866 with the model and date code.
Oct 06, 2010 | Bunn 10 Cup Home Coffee Brewer
Coffee drips slowly and water doesn't drain completly from filling chamber. had machine for about 6 months and was happy until today.All I hear is a humming, a slow drip of half a cup and then it shuts off...
mcdevito75 here, Your coffee maker most likely needs cleaning, Water will leave deposits in the brewings ports over time and will have to be cleaned out, Follow your owners manual on cleaning your coffee maker.
Jun 17, 2010 | Keurig B100 Coffee Maker
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Dec 25, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco royal
Try to set the grinder to grind coarser, make 2-3 cup of coffee to get coffee with the new settings.
/Mirran
Aug 25, 2008 | Saeco Royal Digital Plus Coffee...
The coffee dispenses really slowly.
if our coffee drip try to ajust how fine you grind and amount of coffee if you grind the cooffee to fine its hard for the pressure water to go truh and clean the machine with a decalcifier to remove the calcium buildup more calcium less pressure you have to clean the machine every other mounth cheers
Jan 18, 2008 | Gaggia Syncrony Compact Coffee...
Slow coffee drip
did you change coffee different coffee different setting lower our coffee setting move it only when it grinding only cheers
Dec 07, 2007 | Saeco Vienna Deluxe
Coffee Makers & Espresso Machines Logo
170 people viewed this question
Top Morphy Richards Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Morphy Richards Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
