Question about Home Security
CHUBB SECURE 6000 MANUAL
We have installed a new battery, do we need to reset the alarm
    Sergeant:
  • 165 Answers
2 Suggested Answers
gb96
SOURCE: where will if find a copy of the Chubb Secure 6000
Chubb Secure 6000 is actually just a rebadged / rebranded DAS-NX12.
Do a web search for "DAS NX12 manual" and you'll find all sorts of manuals including installation manuals and user manuals.
If you see the pictures of the DAS NX12 keypad in the manual you'll see its identical to the Chubb Secure 6000.
Posted on Apr 26, 2011
Owners manual
Put key in drivers door lock and turn counter clockwise. must recharge battery or alarm will keep tripping.
May 30, 2013 | 1994 Jeep Grand Cherokee
I have a factory installed alarm on my 2003 jeep cherokee ,how do i disable alarm
Hello! The drivers side door lock/unlock switch is more than likely defective...Having said that, the alarm system on Jeeps are a constant problem...To disable the system requires removing the drivers door panel and cutting the Light Green/Orange wire at the switch...And installing a 465 Ohm resistor...Not something done without the necessary skills...
I would have the vehicle towed to a Jeep dealer and have them test the drivers door switch and disable the alarm....Guru...saailer
Feb 02, 2012 | Jeep Grand Cherokee Cars & Trucks
Replaced battery, but everytime we try to hook up new battery the alarm goes off. What can we do to stop this and allow us to hook up the new battery?
usually with those after market alarm systems the installer will install a reset button under the driverside of dash. just hook up the battery then go push the button or hold it down.
Sep 15, 2011 | 1999 Toyota Camry
I accidentally locked myself out of my Smarthhome Securelinc Alarm Installer Code Model OH-41073AT. I would like to reset the unit to my installer code or create a new one. Can you assist?
The first thing to try would be to disconnect the mains supply and remove the internal battery for a minimum of 5 minutes and then reconnect it.
If this doesn't reset the system then remove the mains supply and battery again for another 5 minutes.
After 5 minutes reconnect the battery.
Then with the help of a friend try holding the # & * keys while they turn the mains supply back on.
These are generic resets for most house alarms but I'll keep looking if there's a specific one for your system so if neither of these work just let me know.
If I find anything else in the mean time I'll add to this post.
Jul 06, 2011 | Visonic INC Smarthome SecureLinc Wireless...
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
Help with battery problem on Timex Ironman Data Link Wrist Watch and after installing a new battery the alarm is silent.
Help with battery problem on Timex Ironman Triathlon after installing a new battery and reset, displays the message 846010 1.0 P1and the alarm is silent.
Jul 08, 2009 | Timex Ironman Triathlon 50 Lap Digital...
Alarm system not working
A friend of ours did some research and discovered it was the ECU (fuse?) that needed to be reset. We removed the ECU (which controls the cruise control, and "learns" the driving patterns of the driver and adjusts the fuel economy) and the car is running fine. To reset the ECU you need to remove the negative cable from the battery, turn the car to "A/C On" (don't crank the engine) for 10 seconds, then shut it off. Replace the negative battery cable. This should reset the ECU. The car does run much better with the new battery. The previous battery was the original and was approximately 6 1/2 years old so it needed to replaced anyway.
Nov 09, 2008 | Hyundai Motor 2002 Elantra
Cobra car alarm
check if the switch in the bonet is damaged (sometimes working under the bonet you could damage the switch and miss it)installing a new battery should not affect the alarm
Sep 08, 2008 | 1997 BMW 318
Home Security Logo
340 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
