Question about Panasonic CT-36G34 36" TV
What causes a blown fuse in tv samsung - Panasonic CT-36G34 36" TV
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Usually in a Cathode Ray Tube Television a blown fuse is either something is wrong in the high voltage power supply section or the flyback transformer is bad, or a bad horozontil output transistor.
Posted on Nov 18, 2013
Have a Samsung tv that won't turn on we have checked all fuses and no capacitors are blown don't know what to do or check next.
hi unplug each board one at a time then turn on. see which one is causing the fault, it's usually the ysus board blows takes out the buffer boards thanks
shaun
Mar 19, 2017 | Samsung Televison & Video
Samsung LN40B500P3FXZA TV has no power. Replaced bad 3.1A fuse but it blew again when attempting to power on. No obvious bad components (blown capacitors). 6.3A fuse is still good.
Since that I have not schematic diagram of your tv... I cannot figured you out the exact part number of those components that caused the problem, but the possible reason why the fuse are always blown when you turned on the unit? because there are some bad filter capacitor, rectifier diodes and power IC regulator in primary power circuit section.
Nov 08, 2016 | Samsung Televison & Video
Samsung led TV un60es8000 dark blotchy area on the upper right of screen. Most noticeable on greys,blues and blacks. The picture attached is the color most responsive to this issue (dark grey). Lighter...
This is caused by one of two things; a bad LED grouping (most common cause) either because the LEDs are bad or the power distributor fuse is blown and the group isn't getting power from the power supply unit. Or two: bad pixel group. But I'd check your backlight power supply for bad connections, blown fuses, or check your led groups for bad leds.
Jan 28, 2015 | Samsung Televison & Video
Samsung 5054x/xaa front panel blown? Can I fix this?!
Hi Camomia,
This type of repair could be a bit challenging but possible if the screen is not cracked.
There is plenty of info on you tube for fixing this model number.
https://www.youtube.com/watch?v=V_9glktklhI
Feb 27, 2017 | Samsung HPT5054 50 in. HD-Ready Plasma...
Samsung lcd will not power on
check for blown fuse, if the fuse is good replace bulged capacitors. if still doesn't works tried to remove the connector going to the inverter board for screen back light might have shorted line that can cause of power failure.
Aug 03, 2012 | Samsung LN55B640 LCD TV
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
I have samsung(hitron) tv purchased around 4 years before. When the external power supply(switch) to tv is switched on, tv is not receiving any power. i mean tv is not functioning. what would be the...
Give me the model number for more accurate diagnoses....
It seems as though there is a DC problem on the power supply, it could be a simple fuse. Or it could be that a fault on another board is causing the power supply to shut its self down.....The TV is in self protect mode because of a short an open component somewhere. Like I said it could be just a fuse has blown. If the indicator light is on then its probably not a fuse problem, but rather an electrical fault.
http://tvtechwork.webs.com/
Nov 17, 2010 | Samsung Televison & Video
Blown fuse
You can purchase it in any electronics shop, just tell them the rating Ex. 3Amp/240Vac you can see this rating at the cap of fuse.
Jun 02, 2009 | Samsung SlimFit TX-S3082WH 30" TV
SAMSUNG STANDARD TV SET
maybe you have a blown fuse,try to have a look first inside,if you have a blown fuse then replace it with the same rating,if it blows again replace your power regulator
Jun 30, 2008 | Samsung TXJ2554 TV
Blown fuse
usually these step up transformers are design for one appliance at a time , let me know the brand and model number of transformer so I can get the specs info , does the stereo also shuts down?? let me know AJ
May 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
Panasonic CT-36G34 36" TV Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
