Question about Ovens
Oven what settings mean
How to set oven
Candy FPP609X oven not heating up
8888 usually means the clock needs setting as it has been disconnected from the mains.
Oct 07, 2017 | Candy Ovens
One controller keeps flashing F2, what does this mean. It will not go to any setting on/off , raise or lower heat setting, etc.
All the information is here. It is a heating sensor error. There is also a video.
If you have a GE oven with an electric ERC, F2 means it is over heating. It is an oven. It is supposed to heat up. For the GE electric ovens and some others, F2 means it thinks the temperature is 590 degrees or higher with the door unlocked or 990 degrees with the door locked.Oct 11, 2015
F2 Google Search
Dec 10, 2016 | Ovens
OVEN DOES WANT TO GET TO SET TEMP.
Do you mean oven doesnt want to get to set tempreture in this case you would test the oven tempreture sensor with an ohm meter between 65-80 degrees inside tempt should be reading between 1000-1100 ohms any less of a fluctuation and you would replace the sensor if you have any further questions message me back Thanks again Rick
Dec 23, 2010 | Whirlpool RBS245PDS Electric Single Oven
F 2 error message when cleaning
Your oven sensor may have died during clean. turn off power open controle pannel , there should be a tech sheet(paper diagram and instructions for service guy) inside. it will have the codes on it as far as what they mean. It should point you to what part to change.
Nov 03, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Setting on knob of diplomat oven
Im pretty sure that settings mean on the 1 line top element only comes on and 2 lines both elements come on hope this helps
Sep 06, 2009 | Ovens
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
I've just moved to a new house and there's no manual for the oven
I just sat down and played with the dials and worked them out.
Jun 05, 2009 | Ovens
Chef regency oven with "HELP" flashing on panel. Have no manual
Usually means that the time needs to be set. Press Clock Set then use the up and down button to set correct time, Then press Manual button.
Apr 16, 2009 | Ovens
Ovens Logo
19 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
