Question about Air Purifiers
Goldair mist fan model GPFM-401
I assembled my mist fan as per the instruction manual and find that if I fill with water there is immediate leakage where the tank goes into the tank holder. Should there not be some form of seal when the to are put together. Please adise.
Why is my clean tank emptying immediately to my dirty water tank?
Hi Medori! It sounds like you have an issue with your pump assembly. We recommend taking your unit in to a Hoover authorized service center. For your convenience I have included a link to our service center locator. Hope this helps!
Service Center Locator
Aug 02, 2014 | Hoover Max Extract Pressure Pro 60 FH50220
How do you take apart a Vicks 3700 humidifier and clean the fan?
Hello Judith,
Here is a Youtube video that should help you clean your humidifier.
If not exactly search through Youtube for more specific details. You may find many helpful videos with proper search, but be sure to watch video completely to be sure it is the task you are trying to accomplish.
PEACE
Kaz com How to clean warm mist humidifier
May 25, 2014 | Vicks V3700 Starry Night Cool Mist...
I put in a new Living Air XL-15 fan but no go.
Make sure that the pin on the back cover penetrates deeply enough into the unit to activate the power. I too couldn\'t figure out why mine wouldn\'t start until I pressed hard on the bottom right corner of the back cover. When I did the unit started immediately because the pin wasn\'t fully inserted. To solve the problem I held the cover tight with a piece of duct tape and haven\'t had a problem since.
Dec 13, 2013 | Alpine Air XL-15 Air Purifier
How much water should i use
I run mine day and night while home and clean and re-fill it every morning. I also use one of the room odor eliminators in my Rainmate. Fill the water one inch above the line about an inch off the bottom of the water container.
Aug 20, 2009 | Rainbow Rainmate Air Purifier
I just set up my new rainmate in my son's room with the eucalyptus scent (he has a cold/cough), and I needed to know how safe is it to leave the unit running overnight, and how long does it take for the...
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful that the bowl is not near the edge of the surface as the spinning water might make it fall off the side. How long the water lasts is also very dependent on how large the room is that its in. Lastly you should be able to leave it run for 24/7
Jan 27, 2009 | Rainbow Rainmate Air Purifier
Rainmate question
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful not to place the machine too close to the edge of whatever it's on as it may fall off. The rainmate can be ran 24/7 (mine does :D)as a side note the only upkeep it should need (other than the water of course) is check the little hole on the bottem of the spinner. if that is ever clogged just punch it though with a toothpick.
Alpine XL-15 fan has stopped working
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
Got Rainmate yesterday and either my house is REALLY clean or it isn't working
i had the same problem. The goo pulled from the air gums up the small orifice atthe bottom of the stem that sticks down into the water. If the water cannot be pulled up into the stem and expelled out towards the bowl at high speed, it cannot work. Take the upper, motor half off, unplug it hold the plate with one hand and twist the stem 1/4 turn and it comes right off. Clean the crud (yes, its your own skin cells) and the hole with warm water and soap. put it back together and refill with water and it works like new. this is now monthly maintenance for me
HTH
May 16, 2008 | Rainbow Rainmate Air Purifier
XL15
The ozone plates need to be cleaned monthly to work effectively. You can get an owner's manual for free from the manufacturer's website, it's at:
http://www.ecoquestintl.com/support/US50300_Living_Air_Owners_Manual.pdf
The manual has a description of the type and frequency of cleaning of various parts of your air purifier. Hope this helps!
Oct 29, 2007 | Alpine Air XL-15 Air Purifier
Air Purifiers Logo
263 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
