Question about Dishwashers
Fisher and paykell nemo dishwasher
Nemo model 820. Continuously beeps when the start or any other button is pushed. Will not start
    Champion:
  • 208 Answers
Door switch
Posted on Nov 18, 2013
  • 351 Answers
SOURCE: Problems with Fisher & Paykel Nemo model DW681.
is there somthing stuck in the wash motor,can you hear a humming noise ? if yes remove motor and see if you can turn it by hand.hopr this helps.
Posted on Mar 14, 2008
SOURCE: Fisher & Paykel Nemo Dishwasher
try ensuring that the container is completely dry before putting in powder
Posted on May 18, 2009
SOURCE: fisher n paykel nemo dishwasher won't go. Sounds
Check to see that the outlet pump (underneath) isn,t stuck eg sumething stopping the pump from turning.Also check that the outlet is clear where it connects to the sink outlet.Hope this helps.
Posted on Dec 13, 2009
  • 3247 Answers
SOURCE: My fisher & paykel dishwasher
please confirm which model do you have 820 or 920.
I am assuming this is the one without display.
most likely cause is the flood switch at the base has actuated. This means water has leaked through the door gasket.
One way to check is to turn power off and draw the dishwasher out from under the sink. May have to disconnect the electric and water inlet.
Tilt the dishwasher to one side and wait for about 1 hour. Try the power on and see if the beep goes away.
You can access this switch by opening the chassis. It is item 5 on page 10 of this parts catalog. You can use a hair dryer to dry the circuit board.
If no help then you have to call the technician as there is not much service information readily available for this model.
See this user manual if you do not have one.
Posted on Jan 24, 2011
SOURCE: dishwasher problem
i had the same problem with a fisher paykel nemo dishwasher beeping at end of cycle, as im a mechanic i was curious to pull it apart and see how it works, i pulled the main control board out and unscrewed the three screws holding it all together and inspected the circuit board, and what did i see, a dry solder on the blue relay box or something, resoldered it, reassembled it and now works a treat, hope that helps
Posted on Jan 26, 2011
Fisher and paykell nemo dishwasher Nemo model 820. Continuously beeps when the start or any other button is pushed. Will not start
I had a similar problem with my Fisher and Paykel Nautilus 920 (same product line more or less as yours). Here's what I discovered was wrong, and how I fixed it ...
Hidden inside the plastic panel at the top of the door, where the operating buttons for the dishwasher are) is is a little switch connected to the door latch that has a blue wire and a cream coloured wire attached to it. What was wrong in mine was the cream coloured wired had become brittle and broken off from the switch. If I pressed any button, all I got was 4 rapid beeps (no error code on the display or anything like that, just the 4 beeps).
If you open the dishwasher door and look inside around the top, you'll see about 6 star shaped screws. These hold the control panel on. You'll need a special screwdriver bit to undo these (luckily I had the right one in a cheap mini screwdriver set I got from eBay that's useful for electronics and computers).
Undo those screws and gently prise the control panel off. (Poke something in the door to stop it from closing completely while you are doing all of this). Check the switch in the middle near the door latch to see if the two wires are still properly attached. In my case the cream one had broken off and fallen back inside the door, but I was able to catch it and fish it out with a pair of kitchen tongs. I used sticky tape to tape it (and the blue one) to the door while I was working so neither of them could fall back inside.
I stripped a bit more plastic off the top of the cream wire then soldered it back onto its connector, then reattached it, along with the blue one, to the back of the door latch switch (take note of which colour goes on which part of the switch before you begin).
Probably the trickiest bit was reassembling the control panel back on. There is a little plastic thing that covers the LED display part that always wants to fall out if you try to do this with the door in the upright position, plus you have to ease the panel back on properly so that the push buttons all line up with the outer flexible covering. I found it easier to lay on my back with the door almost fully open to gently tease things back into position. Also, check that the door latch works smoothly (without closing the door - just squeeze it up and down and makes sure the operation 'feels right'). Once everything is in place, redo the little screws and hopefully you are good to go again!
Ive had this dishwasher for 14 years now and had virtually decided that I would have to buy a new one until I discovered what the problem was and how relatively simple it was to fix. Hope this info helps you or someone else! :)
Oct 04, 2015 | Fisher and Paykel Dishwashers
Fisher & Paykell Nemo model 820 won't start
It sounds like the interlock switch on the unit isn't working, it is a switch than closes when you lock the unit to start the wash cycle. there may be something interfering with it. look to make sure you have a good seal when you lock the unit if not then something is blocking it from sealing properly this will make the buttons give a beeping sound and not work. Hoe this helps.
Nov 18, 2013 | Dishwashers
Fisher and paykel nemo door latch
actually to me it seemed pretty easy ,, i am sure u can do it .
Aug 30, 2012 | Fisher and Paykel Dishwashers
My fisher & paykel dishwasher - nemo model - won't stop beeping. There are no lights flashing and not even turning it off at the wall will help... What is the likely problem?
Jan 24, 2011 | Fisher and Paykel Dishwashers
Fisher n paykel nemo dishwasher won't go. Sounds
Dec 13, 2009 | Fisher Dishwashers
Dishwasher problem
Feb 01, 2009 | Dishwashers
Mar 14, 2008 | Dishwashers
Dishwashers Logo
446 people viewed this question
Top Dishwashers Experts
