Tape stuck Hi there, I have a Philips TV/VCR combi which was fine but then one of my cherubs tried to insert a videotape as I powered the tv, resulting in said tape lodging in the slot. it tries to eject it but then goes back in.Gave up on it and bought an Aiwa....see other post under Stellabelch.
  • Anonymous Mar 10, 2008
    Found on a post from a different site. Seems to be the fix for the tapes getting stuck in the TV VCR Combos.
    I just had a tape stuck in a VCR/TV combo so went on the Internet for help and
    all other answers were to take the top off the VCR which of course is not
    possible with a tv combo.
    While stuck the the power would turn on it would just emit a low moan-whining
    noise for a few seconds starting strong then running down and then power off.
    Couldn't watch TV in that state, it would automatically power off.
    So I got down comfortable on the floor eye level with the input slot with the
    flapping door cover and pressed the power button then quickly with my fingers
    of one hand inserted them in the tape load slot and using my middle fingers
    continously began pushing up on the top edge of the cassette in a stiff but
    quick flicking motion over and over again (like trying to physically force the
    tape up with intermittent prodding short and quick strokes so it could clear
    the lip if the eject mechanism kicked in) while simultaneously pressing and
    holding the eject button with my other hand and after a few tries and 5 or six
    upward prods on the front top edge of the cassette the eject mechanism
    activated and spit out the tape. -Sharon
  • leonard watkinson Jul 07, 2008
    I have a tv/vcr combo, TI 15X5, with panel lock on. I have managed to get partial control with a One for All remote, but a cassette is stuck in and I cannot get any button to release it. Does anyone know the correct code I should be using , or is there a manual solution.
To unlock the front panel of samsung TI-15x5 get a universal remote control which should have TV code=702. Set TV1=702 and you will be able to gain some control of the TV+VCR. To gain control of the setup menu you use VCR code=289 and you will find menu in one of the bottons.
Posted on Feb 09, 2010
Videotape dubbing deck dead
1. Check to see if a tape is jammed inside (see 284 Extract a Jammed Videotape).
2. Try changing the video input and/or output source. Many VCRs have two ways to receive and send a video signal (coaxial and video direct). If that works, try changing the cable for the other method to see whether you need a new cable.
3. Clean tape heads (see How to Clean VCR Heads).
4. Open VCR and inspect any belts that are accessible (see 284 Extract a Jammed Videotape). A drive belt may be broken or loose.
If tapes are getting stuck / enmeshed inside the machine, itis 90% probability) a mechanical problem. Change the Belts, clean all rollers, idlers, and braking pads.
I would suggest that you also replace the Capstan Pinch Roller.
Goodluck..
Feb 17, 2008 | Rio Go Video DDV9556 Dual Deck VCR
Philips combi
How old is the TV? Are the discs you are trying original store bought ones or burnt ones?
Dec 27, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Combi TV/VCR When video tape is inserted TV immediately goes onto "emergency mode" and won't play the tape. Sometimes ejects it str away. TV was 2nd hand so I don't have a manual for it.
The Video portion of the set requires a belt and possibly a drive pulley.
When the tape is inserted, the deck moves it forward then back and if it can't because it has lost its drive due to a belt broken stops dead. Hence "Emmegency mode".
Feb 28, 2011 | Televison & Video
Stuck vhs in vcr
check the tip in my profile
May 31, 2010 | Philips CCC130AT 13 in. TV/VCR Combo
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Sep 22, 2009 | Televison & Video
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
VCR eats the tape
you have a bad take-up reel clutch or a belt on the bottom of the player mechanism that is causing this trouble.
Apr 12, 2006 | Philips VR630 VHS VCR
Televison & Video Logo
295 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
