Question about Lenovo Computers & Internet
Thinkvision menu locked
Display menu is locked
2 Suggested Answers
kamal1984
  • 1383 Answers
SOURCE: UNABLE TO ADJUST THE SCREEN ALWAYS SHOWING MENU LOCKED
When you press power button press continues F8 key then you see safe mode and other menu enter in "ENABLE VGA MODE'
then go to dispaly property and settings then change screen resolution to 1024.768
then apply and ok.
Posted on Aug 18, 2009
How do i get my thinkvison to get out of power saving mode
I do not know how many Thinkvision models are out there, but here is a site that offers manuals you can read online or download.
This is just a page from the manual I found. Here is a link to the manual I found. http://www.manualslib.com/manual/91948/Lenovo-Thinkvision-E54.html#manual
THIS MONITOR WILL APPEAR TO BE NON-FUNCTIONAL IF
THERE IS NO VIDEO INPUT SIGNAL. IN ORDER FOR THIS
MONITOR TO OPERATE PROPERLY, THERE MUST BE A VIDEO
INPUT SIGNAL.
This feature is designed to conserve electrical energy by reducing power
consumption when there is no video input signal present.when there is no
video input signal present.When there is no video input signal, this monitor,
following a time-out period,will automatically switch to an OFF mode. And the
LED will turn orange. This reduces the monitor's internal power supply
consumption. After the video input signal is restored, full power is restored
and the display is automatically redrawn. The appearance is similar to a
"Screen Saver" feature except the display is completely off. The display is
restored by pressing a key on the keyboard, or clicking the mouse. Lenovo ThinkVision E54 User Manual
Feb 28, 2015 | Lenovo ThinkVision Computers & Internet
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
Thinkvision monitor is in power save mode. It is not connecting to Thinkpad laptop
There are 2 possible reasons for this:
- Your Laptop resolution is not supported from the monitor. Solution: reduce the resolution to something smaller (e.g. 800x600) and then gradually increase it untill you have the maximum accepted resolution from the monitor.
- You have not switched the Laptop display to point to the external monitor. Solution: do that b pressing the corresponding shortcuts in your Thinkpad keyboard. (usually a bottom left key together with a top key).
Jul 28, 2011 | IBM ThinkVision L200p 20.1" LCD Monitor
My fan is running but it won't load windows. The monitor says power saving mode
Check the NUM LOCK led status when power on the computer if it is on and off when you press num lock key that means your cpu is working fine only issue with screen resolution for that when you power up th computer press F8 key 5 to 6 times then you can see safe mode and other menu.Enter in "enable vga mode " then go to display settings change scree resolution to 1024*768 then check. but if num lock led stay constant then open cpu cabinet cover reconnect RAM memory.Pull cmos cell from motherboard for 10 minutes then put it back. Reconnect pci or vga card if any. Reconnect processor and it's fan. Make sure motherboard is not ground with cabinet.Also make sure harddrive is recognized in bios if you are able to see bios. For that when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then check. Let me know if you need further assistance. Thanks for using Fixya.
Dec 11, 2010 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L191p after power on, remain black.
First place to chaeck will be power supply, the problem can also be caused by bad inverter circuits, bad lamps, see example of failed monitors due to bad caps, lamps, http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 11, 2010 | IBM ThinkVision L191p (Black) 19" LCD...
then apply and ok.
Aug 18, 2009 | Lenovo ThinkVision L151p (Black) 15 inch...
How to unlock menu in lenovo LCD monitor
Hi :)
I had the same problem and i found the solution .....
Press and hold the menu button on your monitor for 10-15 sec .
Now ..... have fun :)
Rate if was helpful :)
Jun 04, 2009 | Lenovo ThinkVision L151p (Black) 15 inch...
IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Jan 25, 2009 | IBM ThinkVision L170 17" LCD Monitor
Monitor problem
Odd. The manual doesn't mention anything about that. It almost sounds like one or more control buttons is partially shorted or leaky. That can happen if a foreign substance got in it or it was stored in an unheated garage or shed for a long time, etc.
Jan 20, 2007 | IBM ThinkVision L170 17" LCD Monitor
Computers & Internet Logo
51 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
