Question about Panasonic Toughbook CF52 Notebook
Restore sound - Panasonic Toughbook CF52 Notebook
Acer Aspire 7520 gives, most of the time, no sound or audio device in windows 7. 2 days ago I heard sounds coming from this notebook during a fresh install of windows 7, but at that time the moment I...
You can restore your windows 7 earlier restore point.
http://www.blogsdna.com/2039/exploring-windows-7-system-restore-restore-previous-versions.htm
Feb 18, 2011 | Acer Aspire 7520-5185 Laptop
Loss of sound!
You probably uninstalled the drivers for your sound card.
If you know the soundcard model you can download the drivers from the internet or use the drivers CD you got with the computer.
You can also use system restore to restore the computer to date when it was working.
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Jun 19, 2010 | Microsoft Windows XP Professional
My notebook sound is not working.. plzz solve my prob
if your sound was working before do a system restore back to the point when it was working.click, start then hover over programs then go to accessories then system tools, click system restore and pick restore my computer to an earlier time pick a date in bold numbers (ie the date it was working) or before then restore. if this does not work go to this site for a sound driver but only if restore does not solve the problem you dont want conflicting sound drivers http://www.filehippo.com/download_realtek_ac97/
hope this helps
Jun 06, 2010 | Acer Aspire 4720 Notebook
Model: U305-7467 Last week my sound card was working. Now, no sound device hardware is detected by OS. Just like a bunch of other user in the internet...
There are 3 solution for this problem.
  1. You should change your sound card slot where it is inserted.
  2. You Can Restore your windows.
  3. You Can Install New Windows.
If the Problem exist you Replace the sound card or have a local tech take a look at the sound card.
Restore Widows
  • 1st Click on Start.
  • Click on All Programs
  • Then click on Accessories
  • Click on System tools Then
  • Click on System Restore.
  • System Restore window appears
  • Then check this option
  • Restore my computer to an earlier time.
  • Click on next
  • Click on date where you want to restore your system then click on next.
  • And the Restore wizard will start.
  • After sometime the computer will restart.
  • After this hope your problem will solve.
Mar 14, 2010 | Toshiba (4CH-VOUT) Sound Card
My laptop has no sound at all.
There is 1 solution for this problem .
  1. You can Restore windows.
Windows Restore Steps
  • Click on next
Jan 27, 2010 | Compaq Ensoniq AudioPCI Sound Card
I am seeking to restore my computer to an earlier date to get my sound back
You can only restore once you have made a restore point. Then you can restore your system back to the time of that restore point. I don't think going back to a set restore point is going to fix your sound unless you made changes to volume and configurations like muting your sound. Restore points won't put your drivers back in if they are damaged or missing. Open "Control Panel" and then go to "Sound and Audio Devies" Click the option to put volume in taskbar and then open the volume control. Make sure that "Mute" isn't checked and slide the volume controls back up. You should also go to "Control Panel" and "System" then to "Device Manager" and make sure you can see your sound card an that there isn't a mark next to it. Check with the manufacturer of your computer system and see if there are updated drivers for your sound card.
Nov 22, 2009 | Microsoft Windows XP Home Edition
NO SOUND ON MY TOSHIBA LAPTOP
You can try a system restore, ie you can take back your computer to a date when it was working fine .
Running system restore in windows Xp:
Start >All Programs> Accessories >System Tools >System restore
Running system restore in Vista
Start> write "system restore in start search bar "> click system restore
If the system restore doesnot work , try uinstalling the sound drivers from the add remove programs and install the new ones from the link below
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-A25-S207/download/page,sh,30994,221,19,.html
Thanks
proton
Jan 10, 2009 | Toshiba Satellite A25-S207 Notebook
No Sound coming out
Hey There,
You are getting ur problem because ur "SMMedia.dll, SndVol.exe, SndVolSSO.dll or sound.drv"; files are currupted ( Any of them can cause ur system to not plat any sound)..
To come over ride of this problem is,
You need to restore your system using System Restore tool. Follow The following Steps to Restore ur system:
For restoring your system do the following:
1. Go to Start -> All Programs -> Accessories ->System Tools
and select System Restore
2. Go to next window, Choose the restore point that is available, remembering ur system was exactly what you wanted for (choose the point remembering, at particular point ur system was good and playing da sound while u installed particular software).
3. Select that restore point by reading the description (The software you've had installed).
4. Click next to restore.
Note: Your system will restart after choosing the restore point and clicking next. It takes some time to restore.
Thanx.
Gimme your Acknowledge by rating me.
Romy
Dec 25, 2008 | Microsoft Windows XP Home Edition
Sound Restoration
use the oem cd of your loptop it will restore the sound
install it.
Jul 28, 2008 | Computers & Internet
Panasonic Toughbook CF52 Notebook Logo
15 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
