HP DeskJet F380 All-In-One Printer Logo
Posted on May 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp deskjet f380 won't print from external network
I have set up the printer as a shared printer on network it has been set up by my clients tech support. Although the documents are coming through (i Have to turn of my firewall first) to the printer they won't print and just tell me there was an error. I have to delete them then to print from my computer. The tech support that set it up dont know why it wont work?
  • 7 more comments
  • dec_bookkeep May 05, 2009
    Yes it does, but it did the same thing when we tried a home network. it's as if it doesnt want to be shared
    I have just checked and there is no security Tab in printer properties.
    Windows XP Home Edition V202 service pack 3
    Yes the file & Printer sharing option is tagged, and my firewall is operated through norton, which is why i had to disable this before i connected.
    I've done this and now i have no connection to the link. It says Error 800: Unable to establish VPN Connection, Vpn Unreachable or Security Parameters may not be configured properly. This is a headache>>>>
  • Anonymous May 11, 2010
    Open the properties of your network connection. Is file and printer sharing installed?
    Open your windows firewall settings. Is file and printer sharing enabled as an exception?
    Which operating system (and version) has been installed on the computer?
    The printer properties should contain a 'security'-tab. There you can specify which users are allowed to use the printer. Is 'everybody' listed and does it have all rights?
    Does the printer work normally from the computer it's been directly connected to?
Anonymous
Level 2:
  • Expert 67 Answers
  • Posted on May 05, 2009
Anonymous
Expert
Level 2:
Answers
67
Questions
0
Helped
25741
Points
195
Disable Norton firewall (it's just too bad) and enable Windows firewall.
  • Anonymous May 05, 2009
    VPN inside a LAN? I'm afraid your problem is too complex to be solved from distance.
5helpful
2answers
Can i scan over the network on a deskjet f380?
Yes, but the configuration needs to be a network, rather than hosted and shared, setup. After you get the printer connected and working on the network, you need to install printer on each machine, much like if that computer was going to host the printer, then look for the network printer, and good to go...
Network printers work much better and do not require a host computer, after set up.
I have hp deskjet F380 series printer.the problem is my operating system now is windows 2007 and as i am trying to install this it is not getting install as it can only operate in windows xp.so how can i...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and
go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
5helpful
How do you run a print test for an HP deskjet F355 all-in-one printer?
This is invoked at the printer properties and set up page. Look for print a test page.
HP printers often perform poorly if hooked up using Plug and Play. Download the latest install software directly from HP, and follow directions exactly, no plug and play. All computers need the same install for networked printer (meaning not hosted and shared).
1helpful
Computer don't find HP Deskjet F380. He finds
Download & Install the drivers from the vendor website.
Revert back for more assistance.
Problems with HP deskjet f380. Will not print... scans and copies
the system for vista and xp is near to similar. so just click the following links 1 by 1 and go through the instructions as you r missing any minor step to be followed in loading your printer How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
Installing a printer on a Windows 95/98 network
INSTALL THE PRINTER on a PC
ENABLE PRINTER SHARING
MARK the NEW PRINTER as a "Sharable" Printer
INSTALL THE PRINTER ON THE OTHER PCs
Troubleshooting Windows 95/98 networking problems
http://www.mcgill.ca/ncs/products/soho/networking/printer/
How to install a printer driver locally for a remote printer in Windows XP/ Windows 2000-
http://support.microsoft.com/kb/282842
Cant print
Try copying. If you can copying it's the settings on your computer. What is your OS?
HP deskjet F380 all-in-one
re install the driver of your printer...
Cant install my HP printer
You cannot install this in a network, but you can share this printer in the network
Thanks
Riz
k24674
Grand Canyon Tech
Grand Canyon Tech
