Question about Panasonic Televison & Video
CALAGE MECANISME CD - Panasonic Televison & Video
Sunroof retracts fully and lifts but will not close tight on left side
you might be lucky and it just needs the cable greasing. in the mecanisme you will find a cable that is twisted and has brushes on it, use spray grease on this from one end to the other best to do both sides as the cable goes round. also grease the catches , then close the window and put to raised position and from inside spray grease into the arms on either side, run the window back and though though the settings a few times an repeat the greasing as you go.
Jun 18, 2017 | 2008 Ford Escape
My dodge journeys cd player say
My cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix this
Jan 03, 2012 | 2010 Dodge Journey
(CRX230ED) CD-RW Burner will it burn dvds?
Read/Write Speed CD-R Write:
4X, 8X, 12X, 16X CLV
24X ~ 40X P-CAV
52X CAV (turbo mode) max.
CD-RW Write:
4X, 8X, 10X, 12X CLV
16X ~ 24X CAV max.
CD Read:
52X max.
Buffer Memory
2 MB
Random Access Time
100 ms.
Interface
ATAPI/EIDE
Sustained Transfer Rate (CD-R/RW Discs)
600 kB/s (4X CD-R/RW read/write)
1,200 kB/s (8X CD-R/RW read/write)
1,800 kB/s (12X CD-R/RW read/write)
7,800 kB/s (52X CD-R/RW read/write)
Media and Modes Supported
CD-R, CD-RW,
CD-ROM (Mode 1 & Mode 2),
CD-ROM XA (form 1 & form 2),
CD Audio,
Video CD,
CD Extra,
Multi-Session,
Packet Writing
Burst Transfer Rate
PIO Mode 4: 16.7 MB/s,
Ultra DMA Mode 2: 33.3 MB/s.
no you will need dvd rw to burn dvd's
hope it helps
Dec 03, 2011 | Sony (CRX230ED) CD-RW Burner
When I load a cd in my Stanton C324 it reads "No
Hello
Clean your CDs before and after playing them. Although the compact disc has a much longer lifespan than does something like a cassette tape, it can be more fragile. Scratches, dust or other damage to the data side of the CD will cause many CD players to fail to read the CD or cause the CD to skip.
Examine the type and format of the compact disc if your CD player fails to read it. Verify that your CD player can read the type of CD and the files contained on it. Just because you've burned a collection of songs to a CD, for example, doesn't mean that your CD player will be able to recognize that information. You must burn CDs in a specially formatted "Audio CD" mode to play them on a CD player, or your CD player must be able to recognize the MP3 file format. Some CD players have limitations on the type of CD they can read. Verify that your CD player can read CD-R, CD+R, CD-RW or CD+RW compact discs.
Update your CD player's driver, if your CD player is a drive connected to your computer. Click "Start" and select "Control Panel." Click on "Hardware and Sound" and select "Device Manager" under "Devices and Printers." Right-click the icon for your CD drive and select "Update driver software." This may solve any issues the drive was having with playing CDs.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Stanton C324 Mp3 Cd Player With Effects...
Magnavox AZ9855 mini system (7 CD changer), trying to play a cd, the system ejects the CD and message Failed CD is shown. No CD will play.
Hi,when a system eject a CD and with a message "failed CD" It caused by the CD mechanisms that allows the CD to play to damaged that's why the CD keeps on rejecting the CD's being inserted into the CD player.
When you replace the CD mechanism that allow CD to play, problem solved.
Take care.
Oct 06, 2010 | Audio Players & Recorders
When i turn my xl 1s on and i put a new blank tape in it the red tape signal comes up on my screen, any help?
If you don't hear the normal sound, that the camara exept the tape, you problibly forgot to push in the tap of the tape receive mecanisme, before you close the cap. Closing the cap does not cause acceptance of the tape, like other camcorders.
May 25, 2010 | Canon XL1S Mini DV Digital Camcorder
Will it read?
Yes, that's what it looks like. Make sure you put this in the right section next time, though.
Jul 08, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
Help with copying cds keeps saying that I have wrong format
the machine (pc or cd burner) that you are using is looking for a specific type (either cd-r / cd+r)
look on the front of the pc or cd burner to find what type it uses.
cd + r, cd + rw, cd - r, cd - rw or cd-rom. (+/-) r are for one time burning, (+/-) rw is for rewriting over and over and the rom is for games (playstation).......the + (plus) or - (minus) is very important.
feel free to rate if this is helpful
Jun 07, 2009 | Memorex CD 482E (CD-482E) CD-ROM Drive
My rear window wont go up or down 1990 toyota 4runner
I am assuming you have power windows, more than likely your power window motor regulator needs to be replaced. But first your window could have came off its track, to check to see if this is the case (the easy way):
1. inspect the window make sure it doesn't appear to be visibly crooked or cockeyed
2. hit both the front and back of window with the palm of your hand forcefully, but not hard enough to hurt yourself of course :)
3. check to see if window will go up and down now
4. if this doesn't fix it then it's time to replace the power window motor regulator, unfortunately this isn't a job for the average joe (especially if he doesn't have the appropriate tools) so you'd need to take it to a shop
Jan 30, 2009 | 1990 Toyota 4Runner
Chrysler voyager 2.5td se 97
Hi .my car is a diesel motor
I haveproblem whit the gas padel, I tink the eletronic sensor its not reacting.
Its the tipe.(Chrysler Voyager 2.5td Se) a eropean so were can I buy a trole mecanisme with the sensor on It. ??????
Aug 24, 2008 | 2004 Chrysler Voyager
Televison & Video Logo
18 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
