Question about Spar 186 Watts SP-800 Commercial Planetary Stand Mixer
The whisk broken
Where can buy the new whisk please. Is there any distributor in singapore?
Why can't I remove the whisk attachment?
forgot to push up before turning possibly
Mar 21, 2016 | Cuisinart SM-55 Stand Mixer
Hi, I'm from Malaysia.I have a Kenwood Chef model A701A.While creaming cheese the power whisk does not rotate.Could you please help to overcome this problem.thank you.
Hi from the Philippines and welcome to FixYa, I am Kelly
Is it just the power whisk or all attachments that do not rotate? On the A701A there is a clutch and spring fitted to the gearbox. (Spring loaded clutch) There is a pin in the cover that actuates the clutch. If the pin is broken or come out of the cover then the front of the machine will not work. (you may have to have someone fabricate a new pin!) If the clutch spring has broken you will experience the symptom you described also.
There is also a belt from the motor to the gearbox and the belt may have broken or come off.
The belt can be found on Ebay here:
http://cgi.ebay.com.sg/KENWOOD-CHEF-MAJOR-GENUINE-TOOTHED-RUBBER-BELT-197944-/200565225066?pt=UK_Home_Garden_Kitchen_Mixers&hash=item2eb29e766a
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Kenwood Food Mixers
Whisk attachment is stuck on mixer.
I took a small crowbar, and put the curved end up inside the whisk, and hammered the other end lightly. After about 20 taps, the peg was lined up with the sideways opening so I could twist it off. When I got it off, it looked like there was either flour inside the part where the whisk attaches, or some light corrosion was going on. Either way, I'm going to put a little grease in there so it doesn't happen again.
Mar 09, 2010 | Food Mixers
Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Feb 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Trying to locate a wire whisk for my Hobart D-340
Bill. Whisks are not interchangable for different bowls. Try ebay to locate one.
If this solution has assisted you, please rate it. ricardok45
Mar 20, 2009 | Hobart D340-6009 Mixer
KitchenAid Parts
Given the age of a 3-C stand mixer, finding additional parts for it will be exceedingly difficult. The best recommendation is through E-Bay or antiques stores - a specialty dealer. Kitchenaid parts distributors will no longer have anything in inventory for the 3-C mixer.
Jan 03, 2009 | KitchenAid Food Mixers
Whisk
Stove Parts Supply Ft. Worth Tx
Ecolab/GCS equip care
Sep 24, 2008 | Food Mixers
SILLY QUESTION
Push the whisk attachment post up into the mixer, turn counter-clockwise and it should lock into position.
Apr 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
Spar 186 Watts SP-800 Commercial Planetary Stand Mixer Logo
Top Spar Food Mixers Experts
eyecam
Are you a Spar Food Mixer Expert? Answer questions, earn points and help others
