Black Screen My tv went through a power surge and now when I turn it on, the green light in the front comes on, but there is no picture or sound. Is there any way to fix this issue? If so, how?
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house.
Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012 Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012 More results from www.tomsguide.com
Missing: 32dv22u
This is probable the lcd backlight inverter. If you have sound then look at the screen up close with a flashlight and see if there are images. If you can see images then the back light has problems and it is most likely the inverter.
Well if it is DLP TV then crack/ pop sound was broken lamp in TV and if its another kind of TV as you did not mention its model and brand then have to check accordingly.
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
This sounds like when the power came back on a surge went into your tv and burnt out the TVs main power supply or possibly burn out the flyback power converter on the TV main board!
(I am pretty sure it is either one of these things!)
Please rate answer
THANK YOU!
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
