Question about HTC One
My battery takes upwards of 5 hours to charge sometimes which causes a lot of issues since I travel a lot from work via train (hour and a half commute each way). When my battery dies during the day, b
What things can I do to make the battery charge faster?
  • Molly McCaughey
    Molly McCaughey Mar 02, 2014
    This is probably because you are not using the charger that came with your phone, charging it on a computer or laptop, or your charger is broken. maybe your outlet is faulty.
  • HTC Master
  • 2,072 Answers
Honestly nothing. You'd be better off just buying a spare or two. That way you will always have one to use while the other charges. There is newer graphene battery tech coming out that charges in minutes, but it isn't ready for consumer products yet.
Posted on Nov 19, 2013
  • Anthony
    Anthony Nov 19, 2013
    I have the same issue is this something that comes up only with those device? I have a lot of problems with battery life and the time it takes to charge too.
  • Justin
    Justin Nov 19, 2013
    I haven't heard any report of defective batteries in the One, but it is possible. Are you charging off a computer or wall. Wall outlet charging will go faster. The battyer is a 2500 mAH which is about middle to middle-high when compared to other devices.
2 Suggested Answers
  • 19 Answers
SOURCE: Whenever I turn my phone
try toggling the volume bar on the right during boot to see if you get option to do a hard reset. If not, try going to your carrier and borrowing another battery in-store to test. If that does not do it, you are probably looking at buying a new phone.
Posted on Oct 07, 2011
How to determine if I have a Battery issue or a Charging issue with a 2003 H-D FXDXT? What should the Voltage of a "fully charged" 2 year old OEM H-D Battery be. I have a reading of 12.4/5 Volts. At a
Post by the "Owner". The "Fix" was a New Stator. (Broken Wire).
After recharging the 2.5 year old AGM battery 3 times with acceptable results each time. (13+ volts & 14.5+ Volts at high idle) Purchasing a new AGM Battery, a month & a half of "pulling my hair out, all the "great solutions posted on fixya", being stranded 3 times with a "dead battery", I took the Bike to the Shop/Trained Mechanic. Many Thanks to the Post concerning the broken copper wire & "fixya.com" for allowing me to Post. Thank You all.....
May 22, 2014 | 2003 Harley Davidson FXDXT Dyna Super...
AFTER HALF HOUR MY BATTRIES ON MY MOBILITY SCOOTER SHOW GREEN
Could be - I would take the scooter or battery to a car store and they will load check the battery - That is, they will cause the battery to do work, and measure the voltage.
Measuring volts while the battery is at rest will indicate full voltage. That would be a flawed test.
Dec 30, 2012 | Health & Beauty
One train leaves a station heading west, while another leaves two hours later travelling 15km/h faster heading east. After 6 hours the trains are 580 km apart. How fast is each train travelling?
To start out, you need to figure out what the equation for the problem is. You know a few things that should help you along the way:
  • The trains are 580 km apart
  • one train traveled for 6 hours
  • the other train traveled for 4 hours
  • one train is going 15km/h faster than the other.
Knowing these facts you can write the equation 6x+4x+60=580.
The 6 at the front is how many hours the first train traveled. the 4 is the hours the second train traveled. the 60 is (4*15) which is how much faster the second train was going. the 580 is the total distance between them.
Solve for x
10x=520
x=52
So the westbound train was going 52 km/h and the east bound train was going 67km/h.
May 03, 2011 | Texas Instruments TI-30 XIIS Calculator
I have a scootamart large scooter,not sure if 6 or 8 mph.batteries have been checked and are perfect but can only travel 5 or 6 miles on a full charge.what can be wrong.
Hi. How many amp/hours are your batteries?
Who tested your batteries, and how did they test them.
I have had batteries tested by an auto electrical technician, who said the batteries were OK. I knew at the time that the batteries were faulty.
What he did was do a short high current test, that he would normally do on a car battery.
To test batteries in a scooter you have to do a constant current test on fully charged batteries, and monitor the battery voltage. When the battery voltage drops to 10.5 volts across the 12 volt battery, that is considered a flat battery. Take the time elapsed for the test, and you can roughly work out the amp/hour rating of your batteries.
The amp/hour rating of a battery is worked out on a 10 or 20 discharge. A 40 amp/hour battery can supply 2 amps/ hour for 20 hours.
If you take 20 amps per hour, you will not get 2 hours of use. You will probably only get 1.5 to 1.75 hours of use. The more current ( amps ) you take out of a battery, the less amp/hours it will supply.
The best way to test your batteries is a constant current test, but they take a few hours, or try new batteries.
Also how long do you charge your batteries for. Most chargers need to be on at least over night to fully charge your batteries.
Some chargers have a green LED that comes on when the batteries are nearly full. This green LED is a guide only, and most batteries still need a few more hours to do a full charge.
Good luck. Neil.
Jun 10, 2010 | Health & Beauty
Travel pal will not charge
It is time to replace the batteries. Buy two, not just one. This scooter takes two 12 volt, 12 amp hour, sealed deep cycle batteries. If you replace just one, the charger will not charge them properly. Take off the seat (pull upward). Turn the scooter on its side. Remove the six screws (2 in front, 2 under the foot rest, and 2 in the back. Unsnap the old batteries (one at a time) and replace with new. Be sure to keep the wiring as is, so you keep the circuit in series (not in parellel). In fact, before you remove the old batteries, label the connections (A to A, B to B, etc.) so you reconnect just as they were. Total cost is about $200. Time to replace is about a half hour.
Apr 01, 2009 | RTO Mega Motion 3 Wheel Travel Pal Scooter
Reebok resistance rings
Jump Rope for 5 minutes
Stretch
Squat and Press (Tubes)
Functional Push Ups with Rotation
Lunges
Seated Row (Tubes)
Abdominal crunches
Some tips of using this resistance rings while traveling is
Be realistic. Aim to complete 15-20 minutes of exercise per day with a variety of CV and strength training. This will guarantee you maintain your levels of fitness while away.
•Pack your jump rope for cardiovascular training. Skipping increases the heart rate, burn a lot of calories and is great for improving endurance, core stability, coordination, balance and foot speed.
•Pack your resistance tubes. Tubes are a fantastic option for strength training. Exercises are for the entire body, they allow you to train anywhere, anytime with results.
Some other tips:
•Exercise before you leave. This will keep your metabolism high during your flight.
•Stay well hydrated. Drink one glass for every hour while on the plane and avoid alcohol and coffee.
•Never travel hungry.
•Walk and stretch every hour while on the plane to increase blood circulation and reduce muscle stiffness, fatigue and jet lag.
•When you arrive try to get outside. The sun will automatically help to reset your body clock.
Oct 02, 2008 | Reebok New York Giants Eli Manning Jersey
Sidekick 3 battery problems :(
what you do is get a new battery and if that does not help the situation then take the phone into a service center to have it check.
Jun 17, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3
Maybe it's battery. Try to use another maybe helps.
If not it's problem with software in it, what is connected with power point-battery and its showing low battery and switching off.
Second what you can do is to clean connection inside maybe it's stuck something and not giving the power in.
Jun 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
HTC One Logo
108 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
