Question about Ricoh Office Equipment & Supplies
Mp 1900 Functional Problem main switch off then on
Ricoh Mp 1900 Functional Problem main switch off then on
spinal
  • 287 Answers
SOURCE: ricoh aficio mp 2510
Hello e3tech, faatmaan has given you some valuable and accurate information. I would like to offer you some additional information that may help. i am not sure to what degree you have technical experience regarding problems as deep as you are experiencing. I just want to try to help you starting with the basics. We can get the proton accelerator out as a last resort. :-) In the event you have not tried to reset the code (which you can in the event that this code was a temporary condition or erroneous to start with) let me walk you thru the process of resetting the code and lets see if the copier can recover without going into the ugly (but prehaps necessary) and expensive stuff. Again I am just trying to help and this is the first thing anyone should do. We need to enter service mode, usually accessed by the expensive on site technician but you can handle it. This is the first thing I would do if I was onsite. I have been working on copiers for 20 years, which may merely mean I have been on a reign of terroe for that long, screwing everything up! LOL .Ok in order to enter sevice mode on your machine you will need to press the yellow button marked "clear modes" then then numbers 1-0-7 in slow but firm sequence, and the the orange stop clear button and hold IT down tull the screen changes and you will hear a beep. Once again......Clear modes,then 1>0>7 (in sequence) then hold down the orange stop/clear button till the screen changes and you hear a beep. (note....the beep is not guaranteed as it can be turen off prior to what we are doing but you will see the screen change). the new screen may say a number of things but for sure it will have a block named copier. Press that block which will bring up another new screen with all kinds of stuff that you need not be concerned with.The fact that you are at this screen is the cool thing. At this point, turn the main power swith off....!!!!!! THE ONE NEXT TO YOUR LEFT KNEE!!!!!! not the one on the op panel. Unplugging the copier will do the same if you are unsure.The point is to totally de-energize the copier. Turn the copier back on, and this point it will know that some one who knows what they are doing it attempting to help it recover andthe copier will wake up witha new outlook on life and will try to successfully restart back to normal. Without the steps we just went through the copier would have not went through the servicr mode process required foe it to truly have a chance to recover. When you turn it back on, the copier will look at all the critical sub systems it monitors before it feels comfortable to say "READY". In this case the errer code has to do with the very high temperature area called the fuser. As you probably understand, the manufacturer of the copier has designed the copier to keep close tabs on this area as to not burn down your building. So id there is any oddity in this area the machine throws a temper tantrum. So, lets hope hope the machine restarts, and it was a temporary thing , and you wont have to go the route that faatmaan suggested, which again may be absolutely accurate and well detailed. I just thought we could try the reset and hope for the best as it is a genuine and viable option and alot less expensive. I wish you the best. By the way, in the future, ALL error codes you get in the future(and there..are a hell of alot of them) can be reset in the manner I described ealier.This can be a big help for you . It just so happens that this and a few others in the "500" series are less likely to stay reset. I hope I have helped save you alarge wad of cash, but a minimum you are armed with a few valuable tools that may save you buttocks in the future. Take care.................. SPINAL
Posted on Feb 19, 2008
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
  • 86 Answers
SOURCE: How to enter the maintance mode on a Ricoh MP 3350
If you want to enter in Service program mode please,
press Clear (yellow) button, 1 0 7, and press and hold Stop (orange) button for 3 seconds.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
  • 903 Answers
SOURCE: how to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Posted on May 29, 2010
How do i reset ricoh aficio mp 2000
Need for information on problem but try main switch turn off wait 30 seconds then turn on
Oct 21, 2015 | Ricoh Aficio Mp 2000l Copier / Printer /...
My ricoh mp 1900 ink fades away after printing and the cartridge is full . what do I do?
Have you tried cleaning the laser unit? Usually thats the problem, or you need a new PCU (photo conductor unit)
Jul 14, 2014 | Ricoh Office Equipment & Supplies
Help me : Ricoh aficio MP 1900 Error code SC 551
This may help if you tru the following.
Try to reset this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn OFF then ON at the Power Switch.
If the above does not clear it, then it may be time to get a service engineer in as it could be that a board has given up inside.
Good luck.
Jul 05, 2014 | Ricoh Office Equipment & Supplies
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
Ricoh aficio mo 3351 reads messege functional problem detected . SC819
unplug the hard drive and switch on machine, if the problem goes away, then plug the hard drive back in and format it with service code 5-832-001, normally works
Nov 03, 2013 | Ricoh Aficio MP 2000 Black and White...
Sc 544 error for ricoh aficio mp 1900, any possible solution?
I NEED FOR THE lan driver for win server2003 HP PROLIANT ML110 G7
Oct 05, 2013 | ATI AMD Athlon Mp 1900 for Servers 266MHz...
Ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
Functional problem sc 302 in ricoh photocopier model aticio1600
the charge roller in the drum unit is faulty or need to be cleaned.strip the drum unit and clean the unit
Sep 06, 2010 | Ricoh Aficio MP 1600 Black and White...
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
