Lennox e16q3151p what size filter does it take? can I use electrostatic filter?
    Master:
  • 613 Answers
Take the numbers from the existing filter. Don't have one, then just measure the width & length of the inside of the filter housing. Use electrostatic filters only if your unit is equipped to energize it.
Posted on Dec 08, 2013
  • Aleena Meise Mar 07, 2015
    Was wondering how to maintenance this system. Just supposed to change the filter? I'm a new home owner
I have a Lennox Heating/AC furnace - Model CB4-21-1FF-M in which I need a filter. I believe the size should be 12x25x1 but I am not sure. How can I verify what size I need for this furnace.
You're probably measuring the return air opening, inside of the furnace, at the bottom. As long as it covers the opening at the bottom, go with it. Find some means of securing it or holdnit down. And try to go with a common size that's easy to find. 12x25x1" seems to be right.
Mar 16, 2017 | Heating & Cooling
I have a lennox pulse 21 And if i set the thermostat to auto the unit kicks off after a min and the limit switch goes over 200. But if i keep the fan on the unit works fine.
See if you blower speed is set to low speed in the heat mode.
I think what might be happening is the blower is set to low speed in heat and when you switch to automatic, the blower is switched to high speed. You may have to change the blower speed to high in the heat mode. If not you may have an airflow problem such as a Dirty filter, ducts not sized right, dampers on the room outlets closed.
Dec 12, 2016 | Heating & Cooling
What size condensing unit lennox #ca5536vkd2
Your unit uses a LENNOX 11C32 COMPRESSOR COPELAND ZR38K5-PFV-130 3TON 208/230 1PH
Jan 03, 2016 | Heating & Cooling
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
Drip pan wet furnace filter lennox air handler
verymuch so it is clogged up , now open system treat drain pan with bleach ,blow out two lines if there are available but if theres only one treat that on ,then treat the coils clean an treat them after cleaning pour little bleach in the bottom of the pan
May 23, 2010 | Ruud UBHC Air Conditioner
Help. Wrong suction line installed on Lennox HS26-060
Call up the company that installed it. They should be responsible for the work even though it has been 7 years. And if they don't want to replace lines then try to offer to buy the new copper if they throw in the labor. Sounds only right to me. If the person that owns the company wants to keep Lennox warranty. I think they offer 10 years on compressor. But do it as soon as you can I am sure the small copper line is wrong size also. Good luck let me know how it goes. ken
Apr 24, 2009 | Ruud UBHC Air Conditioner
How do I find the filter on a lennox G8Q3904 furnace?
If you don't have a filter "rack" installed then you have to remove the blower housing door. Usually the filter is there if it is not located in the house where the return air supply is. Some units have a filter in what is called a return air filter grill. If there isn't a filter already installed in the unit then you will have to measure the inside dimensions and then use one that is similar in size. It's not imperative that you use the exact same size. You just want to cover the opening of the unit. If you don't have central air conditioning, then it's not necessary to use a filter.
Mar 30, 2009 | Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
