Question about Sewing Machines
Elna1500 My elna1500 won't sew any other stitches except straight even when I move the dials to set
  • Sewing Machines Master
  • 7,365 Answers
There is a good chance that a gear or cam is worn or damaged and the machine needs to be checked at a sewing machine shop.
Posted on Nov 18, 2013
4 Suggested Answers
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
How do I set the dials on husqvarna viking 6000 sewing machine
The "dial" in the back is for decorative stitches which require a "programmer" to be inserted with the stitch formation you want to form. For a straight stitch no cam is required in the back of the machine. The three dials on the front:
Upper Left: Stitch selector
Upper Right: Stitch lenght
Lower: Stitch width
Using the upper left dial select the straight stitch picture
Using the upper right, choose your stitch lenght
Using the lower, choose your needle position, left/center/right
Dec 13, 2014 | Husqvarna Sewing Machines
How do I adust the tenion for a straight stitch on a BrotherXL-3510?
Set the stitch selector to straight stitching.
Set the stitch length to 2.5
Set the thread tension dial (leftmost dial) to 5.
Done
Sep 10, 2014 | Brother XL-3510 Mechanical Sewing Machine
Setting stitch length
Get some scrap fabric. One dial is for the width of the zig zag stitch, the other dial is for the length of any stitch. First set both to ZERO. It won't move then set one to half way. This will show you which dial is which. If it is the width dial. You'll get a bar tack. If it is the length dial you'll get straight stitches.
Aug 01, 2012 | Sewing Machines
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
Model # 64 60 viking sewing machine looking for manual for sewing leather or canvas which cam to use in it
As to your question about leather, the 6460 has a special stitch for sewing leather. Select Colormatic cam C and install in the cam hole at the back of the machine. To remove/add a cam turn the upper left hand dial on the front of the machine to the small dot. This disengages the cam. Gently remove the cam by pulling straight out from the back of the machine. Install cam C straight in, ever so slightly twisting it back and forth into the hole to find the sweet spot. You'll hear a click when it's all the way in.
To use Viking's leather stitch, turn the upper left dial to the color yellow. (Note: The slash line on the upper left dial is a stop. You can't turn past that point. Go in the other direction to get to the icon or color you want.) Turn the upper right and bottom right dial to yellow also. The upper left dial is what selects the particular stitch on the cam, the leather stitch in this case. The upper right dial selects stitch length, and the lower right dial selects stitch width. You can move the right dials within the color range. Experiment on a scrap of cloth to get the stitch size the way you want it. The leather stitch looks like a straight stitch with a block style edging to the right of the straight stitch. This is supposed to give a stronger stitch to the leather rather than a straight stitch by itself.
If you don't have the manual for your machine: Select which of the eight cams you want to use. All the cams are removed/installed by turning the upper left dial on machine front to the small dot. At the rear of the machine, pull/insert cam straight in or out and twist slightly as you push in or remove to find the sweet spot. Move the dial away from the small dot to lock the cam in.
Turn upper left dial to stitch type you want and match the other dials to that same color. Upper right controls stitch length, lower right controls width. Bobbin tension is controlled by the dial at front left of the machine, above the needle.
Cams A-C are the workhorse cams and the rest are embroidery stitches.Straight stitch, button and stitched zig-zag will work on any cam. These stitches do not rely on matching a color code. To use those three: To select straight stitch, on the upper left dial, choose the icon that looks like a buttonhole with a zig that trails off to the right. Select stitch length on upper right dial and turn the lower right dial to zero, going by number rather than color.
To select stitched zig zag, turn upper left dial to the broken zig zag icon (to the right of the straight stitch icon). Select stitch length and width.
To move the needle to the side for buttonhole stitching or other times when you want the needle off center, turn the upper left dial to the button icon. If stitching a button hole, set stitch length to zero and lower right dial to desired stitch width. Push in the small white button that's beneath the lower right dial in order to prevent the feed dogs from moving the fabric forward. Pushing that button in is also handy for putting cloth under the foot before sewing as it prevents snagging and is used for tacking.
Jun 06, 2011 | Husqvarna Sewing Machines
My Kenmore sewing machine model number is 17630, & when I try to set the stitch length from a Straight Stitch setting to a Straight STRETCH Stitch setting, there isn't any difference. I have the length...
Take a look at the stitch length dial. If you turn that dial counter clockwise (to about 7 o'clock), it will set to stretch stitch. Then all of the stretch stitch features will work. When you want to go back to straight stitching, just move that dial back to what ever stitch length you wish.
Nov 26, 2010 | Kenmore Sewing Machines
Will only sew zig zag, even though the dial shows it on straight line.
Check the stitch width dial and see if your model requires the setting be at zero for a straight stitch.
Mar 13, 2010 | New Home Sewing Machines
Shark 384 - how can i get a straight stitch?
with the Shark Euro-Pro X machine, you need to bring the stitch width to zero it's the nob on top of the machine the manual states not to use it wider then 3 with the double needle cause it can break the needle. but either stitch selection "A" or "S" will give straight stitching with width at zero.
Nov 19, 2007 | Euro-Pro Shark 60 - 384
Sewing Machines Logo
44 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
