Question about Whirlpool WED4800XQ Dryer
Whirlpool WED4800XQ Dryer has power but wont start.
I own a Whirlpool WED4800XQ Dryer that does not start when you press the knob. The light in the dryer is lights when you open the door. But will not start in any mode function. Any suggestions, thanks.
  • Jen G Apr 01, 2015
    Could be a bad thermal fuse (part #3392519) that you should be able to replace for about $12-15. If the thermal fuse tests out ok, I'd check the start switch (part #3398095) next. I have this same dryer and have had to replace the start switch no less than 5 times in a little over two years. If the thermal fuse and start switch both test out ok, I'd check the thermostat next. If none of those are the problem, I guess it could be a bad motor.
    Top Expert:
  • Whirlpool Master
  • 10,875 Answers
New timer
Posted on Apr 01, 2015
  • 8 Answers
SOURCE: Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Posted on Oct 25, 2008
jsrock516
  • 5911 Answers
SOURCE: whirlpool dryer
The following link will give you some additional advice on how to troubleshoot a dryer:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Read through the link provided, thoroughly. It does cover many common dryer problems and how to diagnose them.
You know at this point that have power to the unit, because the drum light is working. Now...with the door open, does the light go out when you push the door switch in by hand? Is that how you determined the switch to be good? If the light does not go off, the switch may not be working properly and the dryer will not start. Another easy item to check is the thermal FUSE. The fuse is located behind the lower panel under the door. It is a white plastic component mounted to the top of air blower housing right under the drum in the front. There should be two wires going to it. If the thermal fuse is good, it should read a short (or close to zero ohms). These two first items I mention will kill a dryer from starting and are the most common problems to start with. Read through the section "Dryer Does Not Run at All" and let me know if require further assistance. I hope you find this information helpful.
Posted on Nov 08, 2008
SOURCE: Whirlpool Supreme Dryer will Not Start
I have a whirpool heavy duty dryer that is not working. When I push the button to start the dryer it only roars, and the drum will not move.
Posted on Jan 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: Control Panel in my whirlpool duet dryer model
First check for 220 volts incoming power to the dryer at the terminal block on the rear of the dryer.
If you have 220 volts,check continuity on part number 59(thermal fuse) in the attached diagram. No continuity is a bad part.
cut and paste this link to your dryer diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139909&diagram_id=951915#d951915
Posted on Jul 24, 2010
SOURCE: Whirlpool Duet Sport Dryer -model WED8300SW2 Dryer
Has anyone found the answer to this
Posted on Jul 17, 2011
My Whirlpool LEB6300PWO will randomly not start, or will start but only run briefly then stop. I know these types of problems are not usually related to the timer, but we have found that by either lightly...
Hello, we are sorry to hear that you are having this problem with the Dryer. We would recommend having a certified technician out to take a look at the Dryer and give a proper diagnosis. If you would like further assistance you can reach out to us with your name, phone number, address, model/serial number and the date on which you purchased the Dryer to Whirlpool_Reviews@Whirlpool.com.
Apr 17, 2017 | Whirlpool LEB6300 Electric Dryer
Dryer banging sound inside while running
Check for a loose paddle inside the drum.
Dec 01, 2012 | Whirlpool WED4800XQ Dryer
Want start but is hot all over
By hot do you mean that the heating element is getting hot but the dryer is not tumbling? If so, check to see that the drum belt is not broken.
Mar 31, 2012 | Whirlpool WED4800XQ Dryer
The controls will not come on when I press the power button
if you tapped on it and it work then you have a loose connection somewhere
Aug 27, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Dec 09, 2008 | Whirlpool GEW9250 Electric Dryer
I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T...
Hello dacarle,
Welcome,
You said, I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T START.
Please send me the model number so i can check out the problem.
Waiting your response
Huuum
Oct 15, 2008 | Whirlpool Dryers
Whirlpool WED4800XQ Dryer Logo
194 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
