Question about Samsung AQV12JAX Heat Pump
Cleaning the filters
How does the heatpump open and where are the filters and how do I remove them
    Master:
  • 613 Answers
Remove the return air grille on the top front of the appliance and you'll see it.
Posted on Dec 08, 2013
My Heatpump Unit in the lounge is dripping water onto carpet. I have it set on 22aircon checked the filters and are all clean. Bought this house last year and there was no Manual left. Can you help
in my experience there can be two reasons for this.
The drain is blocked. Often there is a kind of jellified sludge that just needs cleaning from the drain hole. Pour a cup of Javex Bleach down it afterwards.
I have also seen ice build up on pipes as they come out of the compressor. You will see a small ball of dripping frost and ice. You just turn the unit off until it melts and then insulate it with foam or insulating wrap.
Mar 09, 2016 | Heating & Cooling
How do I clean the filter on the Novotronic W 310 Miele washing machine
Cleaning the fluff filter and pump
Check the fluff filter initially after 3 - 4 washes to ascertain how often it is likely to require cleaning. With normal cleaning approx. 2 litres of water run out.
If the drain outlet is clogged, more water will be retained in the machine (up to 25 litres).
Caution: if laundry has been washed at a high temperature,
water draining out of the machine will still be hot!
Take the (yellow) filter flap opener from behind the detergent drawer facia panel. Open the flap.
Place a dish under the drain fixture. Turn the fluff filter lid round 2 - 3
times. Do not take it right out.
With large volumes of water when the dish is full, screw the fluff filter back into position and empty the dish before repeating the procedure.
Once the flow of water ceases, remove the fluff filter completely and
clean it.
Remove any foreign bodies (e.g. buttons, coins, etc.) and fluff.
Turn the impeller by hand to check that it is free to rotate. Any foreign objects causing an obstruction should be removed.
Clean the inside of the fluff filter housing. Remove any deposits of lime scale and detergent or foreign bodies from the thread of the filter housing and filter unit (as these objects can cause a leakage
of water). Put the fluff filter back and screw it in firmly.
Cleaning and care
To clean the water inlet filters
The washing machine has two filters to protect the inlet valves. These filters should be checked every 6 months or so, or more often if there are frequent interruptions to the water supply.
To clean the filter in the union in the open end of the inlet hose:
First turn off the stopcock.
Unscrew the threaded union connecting the free end of the inlet hose to the stopcock.
Remove the rubber seal from the recess. Using pointed pliers, take hold of the plastic filter bar, remove the filter and clean.
Put the filter and seal back in the reverse order and reconnect the
hose. Turn on the stopcock and check the connection is watertight.
Inspect the inlet hose which is subjected to high pressure while the machine is in operation. The hose should be replaced if there are small cracks in the surface, or if it has been otherwise damaged.
If replacing the inlet hose only use a hose able to withstand pressure up to 70 bar. Miele's own hoses meet this requirement.
To clean the filter in the water inlet valve:
Using pliers, carefully loosen the ribbed plastic nut on the inlet valve,
and unscrew.
Use water pump pliers to withdraw the plastic filter by the bar.
Clean, put back and secure.
The two filters must be put back in place after cleaning.
Mar 08, 2015 | Miele W310 Front Load Washer
WIREIN HEAT PUMP FOR COOLING ONLY
You must wire Orange from heatpump low voltage wire to gether with your yellow s and you must have a common wire usealy common comeing out of heatpump should be black color than what ever color wire you have connected to common at t-stat and airhandler connect that to black wire at heatpump. To make sure blablack I s common follow wire up to board and it will be connected to C terminal now you will have ac all time. If you want heat remve Orange wire from reds at heatpump and you will get heat only.note when doing your wireing make sure high voltage is off to heatpump and airhandler hope this helps
Feb 27, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
How can I turn off the freeze protection this units are running in electric heat only is like 32 out side
32 deg s out strip heat will run and if you remove defrost your unit is going to freeze up. When that cold assuming you have a heatpump strip heat is needed .is it a threw wall heatpump?
Feb 18, 2015 | Heating & Cooling
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Heatpump blow out air put not warm
We will need to check and see if the outdoor unit is running when thermostat is set for heat. If not, check the circuit breakers and reset if tripped. Also, check to ensure the high pressure switch isn't tripped (you will likely need to open the panel to see the HPS, it will have a red button on the top of it.
Mar 22, 2010 | Heating & Cooling
Ice coming from unit?? WHy would ice be "spitting" from front indoor wall unit
The unit has frozen up, and the fan is blowing out small particles of ice.
Freeze up is due to Improper airflow, and/or low refrigerant charge.
In the case of a heatpump, it can also be due to a malfunctioning defrost cycle.
Most likely, the filter and/or coils are dirty, causing an air restriction. I'd reccoment cleaning both coils and the filter. Let the system defrost, and run it again. If the problem persists, you have a refrigerant problem.
(or a defrost issue with a wall mount heat pump.)
Feb 07, 2010 | Heating & Cooling
Running high head pressure in heating cycle runs fine in a/c cycle
Check your indoor air filter. When the unit is in heat pump mode the indoor unit is cooling the air, ie. removing the heat from the unit. If the air flow is restricted then the unit will run high head pressure. If the filter is clean then maybe something else is restricting the air flow of the indoor unit. The other possiblity is that the unit is over charged. When in cooling the overcharge will not create the problems that it will in heating mode. The only proper way to charge a heatpump is to remove ALL the refrigerant and then wiegh in the proper amount of refrigerant into the system.
Nov 19, 2009 | Heating & Cooling
LG LDF8812 Diswasher - Self Cleaning Filter not cleaning itself
you should not have to use any type of screwdriver to remove filter. The rest of it , leave alone. Take both rotors out and run unit. Both rotors top and bottom should push water through at a good rate. If not, a blockage in water /motor line. I suspect the rotors simply need to be properly cleaned, If not rotating properly it will cause undesolved residue.
Mar 28, 2009 | LG LDF8812 Stainless Steel Built-in...
Kenmore Quiet3 not cleaning top rack, now stopped cleaning all
The problem is likely that the cutter/chopper filter is plugged. This reduces or eliminates water flow to the cleaning arms.
Solution:
Remove dish baskets
Remove bottom arm - Rotate the centre post until arm is free to be lifted out.
Remove conduit to top arm(s) - Remove 2 screws, one at top and one at back. Rotate whole conduit 45 deg right and lift off of centre post.
Remove bottom plastic assembly. - Remove 4 screws and lift off.
Remove cutter cap. - Remove 1 screw at front left. Lift off plastic cap. Remove cutter filter. It is on a spring loaded pin. Pull cutter blade foreword and lift filter disc straight up. Clean filter disc thoroughly
Reassemble!
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Samsung AQV12JAX Heat Pump Logo
42 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
