How do you adjust a 32 inch jvc tv year 2004 tv
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
About which adjustments you're discussing about? Provide more details please. Service mode adjustments? If so, check the link http://electronicshelponline.blogspot.com/
Posted on Nov 18, 2013
4 Suggested Answers
  • 556 Answers
SOURCE: Lightning spike-dead sets
if it is relay problem you can make it direct just to check.check power supply output. as you say that eht ok than it due to stand by section of system control mcrpssr.
Posted on Sep 13, 2007
  • 133 Answers
SOURCE: I have a JVC SDTV that is about 3 years old. It
Maybe a connection inside the set has been loosened a bit while you were moving the set.
Check the connection contacts on the picture tube neck, unplug the connector (it will probably be soldered onto a piece of circuit board) and see if the pins on the neck are dark (a violet / brownish tinge), if so, you need to clean them with very fine sandpaper (you might need to cut a silicone glue sealing or more of these on the connector to unplug it from the tube neck so check it carefully before trying to disconnect it).
Now check where do the wires from the picture tube neck go - they will probably go to another connector on the main circiut board. Also inspect the pins on this connector and clean them if necessary.
Also check both connectors' solder contacts, one or more pins could have a bad solder contact, you will need to resolder any bad solder contacts (they look like tiny circular cracks in the solder around the pin where it is soldered to the circuit board).
Bad solder contacts can occur on any connector pins and on the pins of any other component, so you might want to check other components too, the components that tend to heat up are more likely to have bad solder contacts (the circuit board around such components will probably have a slightly darker colour, which gives you a good starting point).
It may as well be some damaged component, but if the unit was operational all the way to the point before you moved it, then it is more likely just a dirty connector or a bad solder point.
Hope this helps somehow.
regards
3rq8 (Triarcuate)
Posted on Sep 16, 2009
  • 8457 Answers
SOURCE: current value of a jvc 32 inch color tv 8 years old
About $100 if excellent condition,very good condition about $75-80.Not more than that.
Posted on Sep 27, 2009
Lcd tv has black cloudy line from top of screen about 1 inch wide and 4-5 inch long down the screen
This problem is not just for Philips. I've found similar complaints online for JVC, and my Vizio 32" LCD has the same problem. In my case the TV is about 3 years old and has a lot of hours on it.
Oct 23, 2009 | Philips Televison & Video
Current value of a jvc 32 inch color tv 8 years old
The street value would be 100-150 dollars. If TV is a cheap model or abused or very used, you should pay less.
Consider a Sony or a Toshiba in tube style since all are cheap now.
Sep 27, 2009 | JVC AV-27D302 27" TV
JVC 32" CRT TV BLURRED PICTURE POOR TEXT QUALITY POOR IMAGE DEFINITION CANNOT IMPROVE USING NORMAL COMMANDS
Seems to me you should have to contact a technician to adjust manually the circuit side of it. Usually the screen and focus control knob on the flyback to adjust the settings.
Sep 23, 2009 | JVC AV-32D305 32" TV
LOOKING FOR OPERATORS MANUAL FOR MODEL AV-32890
http://www.retrevo.com/s/JVC-AV-32D302-TVs-review-manual/id/279ag311/t/1-2/ - 65k -
Feb 13, 2009 | JVC AV-32D305 32" TV
Remote control (i hope)
The IR sensor in the tv is probably weak, you could make a mountain out of a mole hill and get it replaced (using your friends receipt ^_^) but there's nothing to be done about the sensor.
Feb 05, 2009 | JVC LT-32P679 32 in. LCD TV
TCL TV picture too dark
try turning the light sensor off
Oct 20, 2008 | JVC AV32F476 32" TV
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
JVC AV-32750
Resolder the vertical deflection output IC421. It is located about three inches to the left of the flyback transformer which is the part with the red cable going to the picture tube.
Nov 12, 2007 | JVC AV-32750 32" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
