Your question: "Philips 50PFP5332D/37 problem with picture. I moved like a month ago and did not set this tv in the new place. Today I finally did and the picture was gone for like 10 sec and then started reappearing but the quality is very poor and there is like a pink shadow of dots what board can be the problem?
    Problem Solver:
  • 22 Answers
Hi i would imagine either the xsus or ysus boards will be causing this. Will be a very expensive problem i'm afraid really a job for an electronics engineer. It is likely that if the fault can be diagnosed to component level rather than board level it can be sorted at a more reasonable price
Posted on Nov 18, 2013
  • 173 Answers
SOURCE: Poor Picture Quality on Philips 42PFL7962D
Get the professional, although this won't be an expensive fix... You likely have one or more caps in the vertical circuit that are going bad... A cap acts like a battery in a circuit taking on voltage and releasing it at an even rate. When they go bad their ESR (equivilent series resistance) rises and the cap takes longer to reach it's op temp and work properly...
A tech with an ESR meter will easily find and repair this one...
no other issues only a minor problem..
Posted on Dec 05, 2007
  • 53 Answers
SOURCE: how many Main Boards are in the Philips 50
the Philips 50'' Plasma TV model 50pfp5332D/37
has only one main board
has many sub bords supporting tat main board
Posted on Mar 08, 2009
zohail
  • 1223 Answers
SOURCE: 17 month old set; Picture gone. Direst TV repairman says it's the backlight bulb. Others say it's a Board.
it might be inverter board it is not backlight bulb according to my expertise bcoz once it goes off it dont come back
but u see inverter and CCFL backlight bulb failing symptoms are so same that u cant simply distinguish but i am sure u have one of these two problems inverter is more chance
Kindly rate me well
Regards
Zohail
Posted on May 23, 2009
  • 4 Answers
SOURCE: Where can I get a video board for a 52
I have original philips videoboards for pfp 5332d, they shoud last normally, maybe the powersupply voltages not proper to it.
Posted on Apr 15, 2010
ricky_PT
SOURCE: I have a 50" plasma Philips tv 50pfp5332d/37 it
feadwf e wrwer we wr rw we r
Posted on Aug 30, 2011
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
Philips 50'' Plasma TV model 50pfp5332D/37 GREEN BLINKING ON LOGIC BOARD
Main digital processor IC on the board has damaged. It is not a replaceable part, as normal soldering techniques cannot be applied to de-solder it out from the board, or to solder a new one in place. Card base replacement should be done.
Aug 14, 2012 | Philips 50PFP5332D 50 in. Plasma...
Most Common problem is Bad Capacitors on the power supply board, they will be vented or swollen on Top. 1000uf 16v 2200uf 10v 3300uf 10v
Jun 25, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
I replaced three cans. they were bulged on the top. i plugged the tv in and it did the same thing. i said it blinks 4 times fast but it is only three. blink code says 3=RESERVED. i pulled the the y-sustain...
Philips lists 3 models of your TV:
1) 50PFP5332D/37
2) 50PFP5332D/37B
3) 50PFP5332D/37E
User Manual for your TV (actually for the 50PFP5332D/37E):
http://download.p4c.philips.com/files/5/50pfp5332d_37e/50pfp5332d_37e_dfu_aen.pdf
The user manual doesn't document the logic board blink codes for errors.
What this tells me is that the TV went thru two revisions before reaching version E.
in case it helps: Philips Customer Support: 1-888-PHILIPS.
If they can't help otherwise, they can at least tell you if your set is eligible for warranty service.
Mar 24, 2011 | Philips 50PFP5332D 50 in. Plasma...
We were watching tv last night and it the picture just turned off. the machine was on but no picture. i turned off the tv and tried again this am. no picture.
You either need this part (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ92-01401-Buffer-Board-/150501144120?pt=LH_DefaultDomain_0&hash=item230a913638) or this one depending on your dead screen issue (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ41-04216A-X-SUS-XSUS-Board-/170550290208?pt=LH_DefaultDomain_0&hash=item27b596e720)
Oct 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
TV sound but no picture
Can you tell me which Cable box you are using?Which model/region?
The possibility is that the HDCP handshake could not have happend correctly and hence the issue. Try to connect to different HDMI input of TV from Cable box. If possible change the resolution of cable box and check video
Nov 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
50PFP5332D/37 has sound and no picture.
try restting push the menu button in on the side for 5-6 second
Sep 05, 2009 | Philips 50PFP5332D 50 in. Plasma...
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philip plasma tv
My parents have a Philips 50PFP5332D/37 the blue indicator light is on but there is no picture or sound. Is there anything I can do to help them fix it outside of calling a tech. I can get parts and fix tvs but unfortunately I am in another state 7 hours aways.
Oct 19, 2008 | Philips 50PFP5332D 50 in. Plasma...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
