Question about BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo) Burner
Benq cd rw 5232x - BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo) Burner
3 Suggested Answers
SOURCE: Benq CDRW 5232X drive, running on Win XP.
puta
Posted on Nov 01, 2008
Mrinny
  • 94 Answers
SOURCE: looking for driver for benq cdrw 5232x
You can download the drivers from here.
Posted on Aug 02, 2010
I have a philips&benq dvd/cd writer, and have lost the icon within the computer section and when I try to use the dvd writer it do's not operate, I have tried updating the drive but it states that my...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 27, 2010 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
Won't respond. Get Corrupted statement code 39
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 10, 2010 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
Cant remove dvd from burner - appears dvd is corrupt
If you have a desktop pc,open the flap that covers your burner.On the front of the burner itself you will see a small pinhole.and by using a strong paperclip push the end through the hole and it will open your burner.You may have to push hard .Hope this helps you.
Regards Bill
Apr 30, 2010 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
Not Reading/writing not even detecting
You need to check the bios on start up. You should have your CD/DVD drive as the first boot device.
Apr 20, 2008 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
How do I install a DVD drive as well as my CD-RW?
mst...First, get your manual out. the drive must be set to be a secondary device unless it is not. You say you have only one IDE...did you remove the CDR? If you have a second IDE or other board connector, then this drive is primary on that. Now, did you install the drivers for the unit? You can use your CDR to do that or get them from the website of the manufacturer. Are there any bent pins on either the motherboard or the back of your drive? Somewhere in there is an answer.
If you have only one drive connector set, you can get a board which will allow you to setup additional drives. Ask your dealer.
Dec 17, 2007 | Computers & Internet
Not sure what disks to use
I have a Fujitsu Seimens laptop and want to download films and dont know what Cds to use?
Dec 15, 2007 | BenQ DQ60 DVD RW Dual Layer Burner
The laser lens in your drive might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo) Burner Logo
32 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
