Question about HTC HD Windows Phone 7
Not allowed to get apps
When trying to get app will just come up saying error internet is on and everything is correct. Why is that happening?
Why cant i downdload apps free
Mate same with me, I tried to uninstall some of my google factory settings but my phone wouldn't let me so I stopped them from updating and after a while I started getting an error code 491 when I tried downloading apps from google play store. I googled 491 and found this link that showed me how to fix it, If it starts happening again then just repeat this link....CHEERS..
http://android.stackexchange.com/questions/83432/downloading-from-play-store-gives-error-491
Mar 16, 2016 | Tablets & eReaders
My tablet won't let me download any apps. Says it's parsing??
Have you checked storage make sure you have room and, try reseting it. Or run back up, if you have it. Also connect to it to your pc and try manually to put apps on. Factory reset and use sd card when you load everything back if you can load the store app on sd, if it happens again you can remove sd delete store app of it and do it again good luck
Jul 04, 2015 | Tablets & eReaders
How do I get to and change my internet filtering content so I can download the apps I want on my Digiland DL1010Q Tablet?
I am curious as to why you want to do something that the os of the tablet doesn't allow anyway .
Feb 13, 2015 | Tablets & eReaders
Tablet won't let me open anything. Bought from a garage sale and she reset it and now it won't work. I tried opening google play and it still wouldn't connect
Because you keep getting "an internet connection error" it sounds like it is not connected to the internet. I would try to address that problem first. I would go in and delete the wifi connection and re-add it using the correct network name and passphrase for your wireless access point. I think that once you get the internet connection error to go away, you will have better results with internet-dependent functions like the app store. Also make sure you don't have airplane mode or other feature activated that would turn off the wifi.
Nov 26, 2014 | Tablets & eReaders
I was trying to install games from my app store on my tablet why did parse error appear
I would recommend restarting your tablet and trying to redownload the app. Usually a a parse error occurs when there is compiling error with the package (app's data).
Essentially it might not have downloaded correctly so restarting the whole process should skip it right along!
Apr 08, 2014 | Tablets & eReaders
How do you reset the android tablet
Hello Pamela
Your apps store was got error you can clean the cache data of your apps store to make it normal.
Steps
1. Go to Settings
2. Go to Applications
3. Select Manage applications
4. Select ALL
5. Find the App Store and click
6. then press/click the Clear Data or Clear Cache
7. Then after that restart your tablet
Try to connect on Wi-Fi then start your apps stor. If the problem not solve that's the time you most reset your tablet.
Mar 03, 2014 | Archos 101 Internet Tablet 16GB 10.1"...
I downloaded textplus on my cruz tablet but it keeps saying internet not found when it is on
I would try deleting the app first-sounds like you might have gotten a bad sector in it & see if that clears everything up & back to normal. If it does, maybe try a different text app. Anytime you get a not trusted server certificate-that is telling you whatever you downloaded it has something bad in it somewhere. I'd get rid of it.
Apr 17, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
How to get google play app on tablet
it gives me my two phones displaying where it says device. neither of them is it. i caanot input the correct device. it will not allow me to do so
Apr 11, 2013 | EFUN NextBook NEXT8P12 8" Tablet
HTC HD Windows Phone 7 Logo
23 people viewed this question
Top HTC Tablets & eReaders Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
matt
matt
Are you a HTC Tablet and eReader Expert? Answer questions, earn points and help others
