Question about OEM 1994 Honda Accord Shock, Rear 3t331810i Without crossmember; Station Wagon 5 door, disc brakes ABS Denver, Colorado
Abs Light Comes On - OEM 1994 Honda Accord Shock, Rear 3t331810i Without crossmember; Station Wagon 5 door, disc brakes ABS Denver, Colorado
  • 4 Answers
Faulty abs sensor get it tested by a mechanic you have 4 of them on all disc brakes!
Posted on Nov 19, 2013
Replaced brakes on 1995 Ford Taurus and now ABS light is on and ABS is disabled
The ABS light only comes on because of a fault. You need the ABS control module scanned for the code that set when the light comes on. There is no RESET
Mar 28, 2014 | 1995 Ford Taurus
91 Buick park avenue abs light. This happened after my friend was driving down the freeway and his tire blew. Now it just blew the rubber off and he was able to drive t off the freeway on the belts. And...
ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti lock brake system light comes up when there is issue with car brake systems. It can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly. Your vehicles brake system needs inspection.
To troubleshoot these issues, I suggest you to refer the help links provided below. There are direct links with accurate solution, for these specific issues.
Click the link below and follow the procedure: ------
All types of ABS LIGHT / brake problems and repairs
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
VCS and ABS lights go on and off intermittently on Lexus?
http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction Control Lights stays ON dash of car?
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Battery Light and ABS Light on Dash
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
How Anti-Lock Brakes Work?
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Anti-lock brake light stays on all the time?
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
2008 Toyota Highlander: ABS warning light Blinking and OBD Error codes Coming?
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
2003 Lexus ES: VSC, TRAC OFF, ABS lights ON?
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
2008 Toyota Highlander Hybrid: Warning Lights Abs, Vsc & Brake Are On?
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
ABS & Brake warning lights remains steady on dash?
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse connected?
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
Where is ABS/TCS module located on 2005 Cadillac Deville
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
ABS motor keeps running?
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON?
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century?
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade?
http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
Toyota Camry: Premature ABS Actuation?
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
Meaning of ABS light
On vehicles equipped with antilock brakes (ABS), a second warning light is provided to warn if a problem occurs within the ABS system. The ABS lamp comes on when the ignition is turned on for a bulb check, then goes out after the engine starts. If the ABS warning light remains on or comes on while driving, it indicates a fault has occurred in the ABS system.
What happens next depends on the nature of the fault. On most applications, the ABS system disables itself if the ABS warning light comes on and remains on.
Oct 24, 2012 | 1999 Ford Ranger SuperCab
Abs light is on and 4wd light comes on and off
2006 Mazda Tribute, ABS braking lights on,Why?
While driving the ABS light comes on and stays on and when I apply the brakes it kinds of shakes a bit.
How to fix this problem?
May 30, 2011 | 2006 Mazda Tribute
ABS light stays on
ABS light comes on with ignition then should go off when you start the car.
If abs sensor does not turn off after disconnecting the battery, then there is a real problem, a faulty sensor or ABS malfunctioning.
When the ABS led comes on immediately after you start the car and stays on usually is one of the relays.
The main one is called surge arrester relay, if it is faulty usually there have been anovervoltage.
There should be two more, usually located behind the black plastic cover of the ABS.
Testing and changing the faulty relay can fix the problem.
If light turns off on startup, and comes back on when you reach some speed, usually you need to check the wheel sensors. You test them unplugging the sensor located behind the wheel and testing it for continuity with a multimeter.
Use Haynes manual to find locations and specs of relays.
Contact a qualified mechanic if you cannot fix it yourself, problems with ABS may compromise safety of the vehicle
Jun 03, 2010 | 2004 Ford Explorer
ABS LIGHT COMES ON AND DISENGAGES THE ABS BUT
When the ABS light is on the ABS system is deactivated. Meaning, when the abs is light is on and you brake, the tires will lock up with heavy braking.
Escapes have a common issue of the ABS excitor rings cracking causing ABS problems. Sometimes it activates on almost every brake application. It may set a code in the ABS computer for an intermitten wheel speed sensor or no wheel speed signal. Check all the "rings" on the outside of all four axleshafts. If none of the rings are cracked it is likely a bad ABS wheel speed sensor.
Feb 20, 2010 | 2002 Ford Escape
I have a subaru legacy outback, abs light comes on
one of your abs sensor is bad or the abs motor,go to local shop to diagnose which sensor,shop usually charge $ 60 to diagnose abs system,good luck, let me know ..
Jun 04, 2009 | 1996 Subaru Legacy
Abs light in 1999 chevy malibu
1999 chevy malibu abs light stays on
Jan 06, 2009 | 1999 Chevrolet Malibu
OEM 1994 Honda Accord Shock, Rear 3t331810i Without crossmember; Station Wagon 5 door, disc brakes ABS Denver, Colorado Logo
62 people viewed this question
Top OEM Computers & Internet Experts
David Payne
David Payne
David
David
Are you an OEM Computer and Internet Expert? Answer questions, earn points and help others
