Honeywell cm67 instructions
I have a Honeywell CM67 thermostat controlling under-tile heating in my bathroom. I can't program the various time zones or turn the whole thermostat off. It is running at 36degC 24 hours a day.
5 Suggested Answers
  • 37932 Answers
SOURCE: why will my programmable honeywell thermostat not keep changes to my schedule
Could be batteries need replacement
Posted on Apr 28, 2013
  • 5221 Answers
SOURCE: need to find out why my honeywell rht4650d thermostat is reading "in recovery"
The problem is likely with the cooling system, not the thermostat itself. Either the message from the thermostat is not being received by the AC unit, the solenoid isn't turning on the unit or it can't cool properly.
First check that none of the wires to the thermostat are loose or broken. You'll have to take the face plate off to check. The conductors are very small wires and can break easily. Depending on the unit,there are 4-5 wires usually for a HVAC system. If a wire is loose, reconnect it (push it in or screw it down gently). If a wire is broken, strip (for screw terminals) a new section and reconnect it. Check for ice build up on the condenser coils. (That is often a sign of a refrigerant leak. You'll need a professional to fix it and recharge the unit.)
Do you hear the fan running? If you do, then the condenser is a likely culprit. If the fan isn't running, then the control board for the system may be bad. You may want a professional to check the system. If you tell them the make and model, the technician can bring the parts if it is a problem with the control board.
I hope this helps.
(We had the broken wires to our thermostat in the winter. A few years ago, a nearby lightning strike had the AC off in the summer due to the control board damage. The house reached 90 degrees while we waited for the repair.)
Posted on May 31, 2013
mikadot
  • 2113 Answers
SOURCE: i have a honeywell thermostat t6360.the light
Many thermostats have battery backup as well as the 24 volt ac. Have you replaced the batteries to see if it fixes all of your issues at once?
Posted on Nov 02, 2013
  • 37932 Answers
SOURCE: how do i reset my honeywell cm67 thermostat the screen is blank
The replacement batteries may be defective or installed incorrectly.
Posted on Feb 07, 2015
How do i reset my honeywell cm67 thermostat the screen is blank
Feb 07, 2015 | Heating & Cooling
Honeywell CM67 hydronic heating. Our sleep and out of the house temperature is programmed at 17.5, our in-house temp is programmed for 20.5. Problem is the thermostat is staying fixed on 17.5 for the...
I would say get a professional person to deal with it. Could mean a new thermostat. Is it battery operated? maybe the battery is low . I would replace the battery and see if that works before spending more money.
Aug 25, 2017 | Honeywell Programmable Thermostat Heater
Directions to program cm 67 thermostat
How do I set one temperature for the whole day?
To operate as a simple thermostat with one temperature throughout the day, move the slider to the MANual position. Adjust the manual temperature by pressing the TEMPerature or button. The manual temperature can be set anywhere from 5°C to 30°C in 0.5°C steps.
Here is the User Guide for the CM67 Thermostat:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
May 17, 2011 | Honeywell Heat/Cool Thermostat
Honeywell cm67 thermostat operating instructions
You can grab a copy of the owner's manual here.
Please rate this replay - thanks!
Dec 01, 2010 | Heating & Cooling
Hi there ive got a honeywell cm67 room stat which im trying to fit but not going to plan need help please
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 30, 2010 | Heating & Cooling
Replacement of heating programmer
yea you should be able to just when you remove the old one mark witch wire went to witch connection by marking it some how i personaly take one wire at a time wrap it with a small piece of white tape and write the letters on the piece of tape then when i replace with the new one i cant mess it up also look for any of the wire connections to see if any have to be or have been jumped out
Nov 14, 2008 | Honeywell Water Heaters
My heat is turning on but the fan isnt working. my honeywell thermostat is showing a flame and a blinking battery, and i know nothing about this thermostat, we just moved in . Can u help?
This is not a PC problem
Symptom
Heating comes on, but sometimes it
gets too hot, sometimes too cold.
Neutral not connected
Cure
Check wiring in room thermostat. Look for a
connection to the Neutral terminal (N 2 on
the Honeywell T6060, T6160, and T6360).
Make sure that it is connected (check
continuity).
If there is no neutral available, replace with a
two-wire thermostat, e.g., CT200, CM61 or
CM67. These will also offer extra energy
savings, (Without a neutral connection, the anticipator within the room thermostat does not work,
so the temperature control reduces from ± ½ºC to ±3ºC. People can feel a six degree
temperature swing. Then, if they try to adjust the room thermostat to overcome the
problem, the temperature swings become even worse.)
Mar 16, 2008 | Computers & Internet
Central heating thermostat
Looks like it was replaced by the CM67 series, try this link for the manual:
Geno
Feb 29, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
