Question about Canon IR 3300 Digital Copier
Hi my canon ir 3300 giving duplex jams, wen i makes single sided copies it coming without any problem wen i makes 2sided copies 1st 2 0r 3 copies come wintout any problem after that the paper goes through the drum unit , wen it just enters to the fixing area paper folds like z shape then it jams. i have changed fixing unit ,changed sensors , feed rollers even drum and blade then also the same is occuring in same way . what should i do plzzz help me thanks in advance
SOURCE: Canon Printer model IR 3300 making noise while printer
Clean rollers of debris
Posted on Jun 28, 2007
muleskinner2
  • 270 Answers
SOURCE: repeated paper jam in the fuser unit
There could be two problems with the copier:
1. There has been a Canon mod for the two pads already suggested earlier. Remove the two pads and place a foam strip that is runs across the top of the lower right access door basically between those two pads. This creates more even pressure across the deflector for the upper paper cassette.
The style of roller above the exit for the paper cassette is now gray in color instead of black.
Posted on Nov 13, 2007
checkitright
  • 1362 Answers
SOURCE: Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
Posted on Aug 25, 2008
Joed911
  • 4338 Answers
SOURCE: canon mx850, paper jams when reloading for two
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 21, 2009
canontech
  • 1219 Answers
SOURCE: Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Posted on Mar 02, 2010
Why are copies dark at top, light at bottom? - Canon IR 3300 Digital Copier but computerice print is ok good
1. Glass could be dirty, smoggy
2. Lid that is not closing on the one side.
3. Scanner unit faulty.
Nov 06, 2015 | Canon Ir 3300 Black & White Copier
Hi. I have a Canon IR2018 printer in my office. Because I am eco-wise I would like to set it from single to double sided printing (I think that's the term for printing on both sides of the paper) but...
you can do so if your machine has a duplex unit attached.if it has a duplex unit then for printing you have to select 2 sided profile as default or for prints when u want double sided from you pc print software(canon) or the server if you have one .that way u will get all the prints in 2 sided. for copying u have to select 2 -2 sided by pressing the 2sided key on the console of the copier.then place the originals in the ADF and thats all
Jul 15, 2011 | Canon imageRUNNER 210S Copier
How do you copy front and back?
1. First make sure you are in Copy Mode
2. Load document
3. Enter the number of copies you want using the number pad
4. Press Duplex and "up arrow" or "down arrow" to select 1sided>2sided L
5. Press Start to copy the document.
FYI - if you get an Out of Memory message while making duplex copies, you might need to install extra memory.
Mar 01, 2011 | Brother MFC8890DW AllInOne Laser Printer
How to solve 2side paper jam its in continue but 1 side is working good...how to solve this problem? its ir 400 canon machine
open the front cover and clean the duplex rollers with alcohol and dry it.
Also, if you have stand for these copier, on the left side of the stand there is opening on top of stand where the copy is going when it copy second side, check for any opsticles in there.
Hope that helped
Aug 06, 2010 | Canon imageRUNNER 400S Copier
Hey I have installed a duplex unit in my canon iR2018 it was copying normally before I install it and now it is having paper jam after installing the duplex unit
did you properly conect the all connectors?
See instalation manual.
Maybe the duplex unit didnt set very well.
Where paper jam occurs?
Try to clean all rollers on duplex, maybe the unit were very long time stored badly.
Pls. give more info!
Jun 14, 2010 | Canon iR 2016i Black and White Copier
Steps to make an automatic double sided copy
Hello sir; That is depend on your machine have duplex unit or not if doesn't come with duplex unit you can not do it.
May 30, 2009 | Canon imageRUNNER 5570 Copier
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
beergut707
Oct 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Problem in Canon Laser Shot LBP 3300
Their is Button in the rear of the printer a Blue jack push it inside for duplexing LGL /LTR size paper and pull outside for duplexing A4 size its easy
Dec 01, 2007 | Canon LASER SHOT LBP 3300 Printer
Canon IR 3300 Digital Copier Logo
81 people viewed this question
old marine
old marine
